Puritan Bennett 560 Internal Battery Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Puritan Bennett 560 Internal Battery Replacement, Internal Battery: step 1, image 1 of 1
    • REMOVAL
    • Locate the battery cover on the rear of the ventilator.
    Ask FixBot
  2. Puritan Bennett 560 Internal Battery Replacement: step 2, image 1 of 1
    • Using the T10 Torx screwdriver, remove the three 8mm screws on the battery cover.
    • Two screws are located on the rear of the ventilator, and one on the bottom.
    • Slide the battery cover out of the ventilator.
    • Remove the battery from the battery cover.
    Ask FixBot
  3. Puritan Bennett 560 Internal Battery Replacement: step 3, image 1 of 1
    • REPLACEMENT
    • Install the battery into cover, as shown in figure.
    • Make sure the contacts on the battery line up with those in the ventilator.
    • Slide the battery and cover together into the housing.
    • While applying pressure to the cover, install the two rear screws.
    • Install the screw at the bottom of the cover.
    • Be careful not to over-tighten any screws.
    Ask FixBot
Finish Line
2 other people completed this guide.
Theo Philliber
201 Reputation
1 Guide authored
Cal Poly, Team S11-G20, Paton Spring 2020 Member of Cal Poly, Team S11-G20, Paton Spring 2020
CPSU-PATON-S20S11G20
2 Members
3 Guides authored
1 Guide Comment
I can’t seem to edit the step titles. They should show:
Step 1: Battery Removal
Step 2:
Step 3: Battery Replacement
Theo Philliber - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 38
All Time: 816
