Puritan Bennett 560 Exhalation Block Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
54
All Time:
761
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
This guide will explain how to remove and replace the exhalation block in the Puritan Bennett 560 Ventilator. If you decide to clean the exhalation block for use on the same patient follow the proper use procedures below.
Proper Use:
  • The exhalation block is for a single patient only and must be replaced for each new patient.
  • It can be removed from the ventilator and cleaned for use on the same patient by washing with soap and water.
  • If cleaning the exhalation block, ensure that it is completely dry before reinserting it back into the ventilator. This ensures that no damage is done to the ventilator electronics.
    • The exhalation block can either be left to air-dry, or blown dry with compressed air.
The repair information is also available on pages 144-145 (Section 5, Pages 14-15) of the Service Manual that is linked in the documents section.
    1. Puritan Bennett 560 Exhalation Block Replacement, Exhalation Block: step 1, image 1 of 1
      • Locate the exhalation block on the front of the ventilator.
      Ask FixBot
    2. Puritan Bennett 560 Exhalation Block Replacement: step 2, image 1 of 1
      • Tilt the machine up and unscrew the knob that holds the exhalation block in place.
      • This knob can be untwisted by hand, no tools required.
      Ask FixBot
    3. Puritan Bennett 560 Exhalation Block Replacement: step 3, image 1 of 1
      • Pinch the "From Patient" fitting and slide the exhalation block away from the ventilator.
      Ask FixBot
    4. Puritan Bennett 560 Exhalation Block Replacement: step 4, image 1 of 1
      • After replacing or cleaning the block, perform the exhalation flow sensor calibration.
      • See 6.7.3.3 in the Service Manual for instructions on calibration.
      Ask FixBot
2 other people completed this guide.
Kyle Hammer
292 Reputation
2 Guides authored
Cal Poly, Team S11-G20, Paton Spring 2020 Member of Cal Poly, Team S11-G20, Paton Spring 2020
CPSU-PATON-S20S11G20
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 54
All Time: 761
