Up to 20% off select tools
Purewell Gravity Water Filter Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
161
All Time:
2,206
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Purewell water filters are known for their reliability and clean-tasting water, but like any home appliance, they can experience issues over time. This guide will mostly focus on the filter as it is one of the most common problems with the water filter.
In this step-by-step repair guide, you’ll learn how to:
  • Disassemble and inspect key components
  • Clean, unclog, or replace parts as needed
  • Reassemble and test your filter for proper function
    1. Purewell Gravity Water Filter Replacement, Water Filter: step 1, image 1 of 3 Purewell Gravity Water Filter Replacement, Water Filter: step 1, image 2 of 3 Purewell Gravity Water Filter Replacement, Water Filter: step 1, image 3 of 3
      • Remove the lid of the water system.
      • Lift the top half of the water system to remove it.
      Ask FixBot
    2. Purewell Gravity Water Filter Replacement: step 2, image 1 of 2 Purewell Gravity Water Filter Replacement: step 2, image 2 of 2
      • Place the top half near a sink.
      • Turn it over so you can reach the wingnuts and washers underneath.
      Ask FixBot
    3. Purewell Gravity Water Filter Replacement: step 3, image 1 of 3 Purewell Gravity Water Filter Replacement: step 3, image 2 of 3 Purewell Gravity Water Filter Replacement: step 3, image 3 of 3
      • Rotate each wingnut counter-clockwise to loosen the filter.
      Ask FixBot
    4. Purewell Gravity Water Filter Replacement: step 4, image 1 of 2 Purewell Gravity Water Filter Replacement: step 4, image 2 of 2
      • Flip it over so the top is accessible.
      • Remove the wingnuts and washers from the bottom of the top section.
      • Remove the filter out of the system.
      • Remove the washer from the filter.
      Ask FixBot
    5. Purewell Gravity Water Filter Replacement: step 5, image 1 of 2 Purewell Gravity Water Filter Replacement: step 5, image 2 of 2
      • Place the primer button on to the filter.
      • Ensure the primer button is aligned with the filter attachment.
      Ask FixBot
    6. Purewell Gravity Water Filter Replacement: step 6, image 1 of 3 Purewell Gravity Water Filter Replacement: step 6, image 2 of 3 Purewell Gravity Water Filter Replacement: step 6, image 3 of 3
      • Turn the sink on low so the water runs slowly.
      • Press the end of the filter with the primer button firmly against the faucet to ensure water flows only into the filter.
      • Wait for the filter to start sweating to remove the filter away from the sink.
      Ask FixBot
    7. Purewell Gravity Water Filter Replacement: step 7, image 1 of 3 Purewell Gravity Water Filter Replacement: step 7, image 2 of 3 Purewell Gravity Water Filter Replacement: step 7, image 3 of 3
      • Remove the primer button and place the washer back on the filter.
      • Place the filter through the hole in the bottom of the top section of the system.
      Ask FixBot
    8. Purewell Gravity Water Filter Replacement: step 8, image 1 of 3 Purewell Gravity Water Filter Replacement: step 8, image 2 of 3 Purewell Gravity Water Filter Replacement: step 8, image 3 of 3
      • Flip it over so the bottom is facing up.
      • Make sure the filter to hold the filter so it doesn't drop out.
      • Rotate the washer clockwise and tighten the wingnut until it is securely attached.
      • Avoid overtightening the wingnut and washer, as this can make it difficult to replace the filter next time.
      Ask FixBot
    9. Purewell Gravity Water Filter Replacement: step 9, image 1 of 2 Purewell Gravity Water Filter Replacement: step 9, image 2 of 2
      • Place the top half back onto the system and replace the lid.
      Ask FixBot
Finish Line
Author
with
Alex Lam
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 161
All Time: 2,206
