Up to 20% off select tools
Punkt MP02 Keyboard Membrane Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
68
All Time:
357
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your keys for your Punkt MP02 are damaged or faded, you can follow these steps to help you replace the keyboard membrane. A damaged membrane should often be replaced because it can cause mis-clicks or frustration when typing. However, check out our troubleshooting guide for "buttons not registering" first to ensure it is hardware and not software-related. Before you begin, backup important data, and power off the device to ensure no data loss throughout the process.
    1. Punkt MP02 Keyboard Membrane Replacement, Battery: step 1, image 1 of 2 Punkt MP02 Keyboard Membrane Replacement, Battery: step 1, image 2 of 2
      • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
      Ask FixBot
    2. Punkt MP02 Keyboard Membrane Replacement: step 2, image 1 of 2 Punkt MP02 Keyboard Membrane Replacement: step 2, image 2 of 2
      • The back panel is held on by glue and multiple tabs.
      • Slide a Jimmy into the seam between the back panel and the chassis.
      • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
      • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
      Ask FixBot
    3. Punkt MP02 Keyboard Membrane Replacement: step 3, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement: step 3, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement: step 3, image 3 of 3
      • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
      Ask FixBot
    4. Punkt MP02 Keyboard Membrane Replacement: step 4, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement: step 4, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement: step 4, image 3 of 3
      • Insert a Jimmy into the seam between the front and back case.
      • Slide the Jimmy around the perimeter while prying to separate the front and back case.
      Ask FixBot
    5. Punkt MP02 Keyboard Membrane Replacement: step 5, image 1 of 2 Punkt MP02 Keyboard Membrane Replacement: step 5, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Make sure to pry under the connector itself and not on the board.
      Ask FixBot
    6. Punkt MP02 Keyboard Membrane Replacement: step 6, image 1 of 2 Punkt MP02 Keyboard Membrane Replacement: step 6, image 2 of 2
      • Gently pry the battery off with the spudger tool.
      • Take care not to bend, warp, or puncture the battery during removal.
      Ask FixBot
    1. Punkt MP02 Keyboard Membrane Replacement, Screen: step 7, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement, Screen: step 7, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement, Screen: step 7, image 3 of 3
      • Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
      Ask FixBot
    2. Punkt MP02 Keyboard Membrane Replacement: step 8, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement: step 8, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement: step 8, image 3 of 3
      • Remove the antenna coaxial connectors on the board with a spudger by gently prying straight up where they are connected on the board.
      Ask FixBot
    3. Punkt MP02 Keyboard Membrane Replacement: step 9, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement: step 9, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement: step 9, image 3 of 3
      • Flip up the two black locking flaps securing each of the two ribbon cables.
      • Disconnect the two ribbon cables.
      Ask FixBot
    4. Punkt MP02 Keyboard Membrane Replacement: step 10, image 1 of 2 Punkt MP02 Keyboard Membrane Replacement: step 10, image 2 of 2
      • Using your thumbs, push the board up so that the clip can slide out of the indent.
      • Use a spudger to gently separate the boards.
      • Ensure that the antennae slide through the holes—do not accidentally pull these off.
      Ask FixBot
    5. Punkt MP02 Keyboard Membrane Replacement: step 11, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement: step 11, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement: step 11, image 3 of 3
      • Use a spudger to lift and disconnect the screen press connector.
      • Make sure to pry up on the edge of the connector, not the board itself.
      • Remove the screen.
      Ask FixBot
    1. Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: step 12, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: step 12, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: step 12, image 3 of 3
      • Remove the 3 (3mm) Phillips head screws from the board.
      Ask FixBot
    2. Punkt MP02 Keyboard Membrane Replacement: step 13, image 1 of 2 Punkt MP02 Keyboard Membrane Replacement: step 13, image 2 of 2
      • Use a spudger to gently pry the board up and remove it.
      Ask FixBot
    3. Punkt MP02 Keyboard Membrane Replacement: step 14, image 1 of 3 Punkt MP02 Keyboard Membrane Replacement: step 14, image 2 of 3 Punkt MP02 Keyboard Membrane Replacement: step 14, image 3 of 3
      • Peel the keyboard membrane off the phone casing.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Gloria Enchill
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 68
All Time: 357
