Up to 20% off select tools
Prototyping a Board
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
61
All Time:
591
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Prototyping a Board
    1. Prototyping a Board, Board layout using EAGLE: step 1, image 1 of 3 Prototyping a Board, Board layout using EAGLE: step 1, image 2 of 3 Prototyping a Board, Board layout using EAGLE: step 1, image 3 of 3
      • Create the board layout using EAGLE FREE on more information on this step.
      • A video tutorial for using EAGLE for a board layout can be found here.
      • Remove all the labels and export it as a monochrome image (.png).
      Ask FixBot
    2. Prototyping a Board, Convert to .rml file: step 2, image 1 of 2 Prototyping a Board, Convert to .rml file: step 2, image 2 of 2
      • Upload the image to fabmodules.org.
      • Output format for "Roland mill (.rml)".
      • The process box is how thick you want the cuts. Select "PCP traces (1/64)".
      Ask FixBot
    3. Prototyping a Board, Setting up the output: step 3, image 1 of 2 Prototyping a Board, Setting up the output: step 3, image 2 of 2
      • From the output menu, select the following: Machine: SRM-20, X0: 0, Y0: 0, X0: 0. Leave the rest as default.
      • Then select the "calculate" button.
      • Next select the "save" button.
      • The image shows the cut cut patterns. (The red lines are where the machine is picked up and moved to the next spot to cut.)
      • Repeat steps 2 and 3 but with the minor change of selecting "PCB outlines (1/32)" in the "process" option.
      Ask FixBot
    4. Prototyping a Board, Starting the Roland SRM-20: step 4, image 1 of 2 Prototyping a Board, Starting the Roland SRM-20: step 4, image 2 of 2
      • Push the green button to turn on the Roland SRM-20 and plug the machine's USB into computer. Note: it must be a windows computer.
      • Open the program VPanel for SRM-20. You can download the program and manual here.
      • Hit the "on" button to run the machine for a minute to allow it to warm up.
      Ask FixBot
    5. Prototyping a Board, Adding file to VPanel: step 5, image 1 of 3 Prototyping a Board, Adding file to VPanel: step 5, image 2 of 3 Prototyping a Board, Adding file to VPanel: step 5, image 3 of 3
      • Select the "cut" button which will bring up a new window.
      • Click the "add" button to add a file.
      • Add the file and click "open".
      • Then select the "output" button.
      Ask FixBot
    6. Prototyping a Board, Setting up the Roland SRM-20: step 6, image 1 of 3 Prototyping a Board, Setting up the Roland SRM-20: step 6, image 2 of 3 Prototyping a Board, Setting up the Roland SRM-20: step 6, image 3 of 3
      • Set the bit and the material. And set the "home" for xy and for z. See the manual for these instructions.
      • Note: you will see this dialog box when you set the "home". Select "yes".
      • Note: there is a sacrificial board on top to protect the machine.
      • Once everything is ready, select the "output" button. This will begin cutting process.
      • Click here for a more detailed tutorial from an outside site.
      Ask FixBot
Finish Line
Author
with
Brooke Mason
2,958 Reputation
17 Guides authored
Open-Storm Member of Open-Storm
Community
16 Members
276 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 61
All Time: 591
