Up to 20% off select tools
Protocol Videodrone AP Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
65
All Time:
752
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the camera module for the Protocol Videodrone AP Drone. This is a slightly lengthy process as you will have to disassemble most of your drone. The camera module itself is both the sensor housing + the circuit board connected it it. You will only have to replace the circuit board, as the sensor housing is attached to it.
Remember to use the included #0 Phillips screwdriver that came with your drone.
A soldering iron is required, so keep one ready. If you're not experienced with soldering, take a look at this guide for How to Solder and Desolder Connections.
Before you begin, make sure that your drone is turned off and it's unplugged from the charger. You should also remove the battery before you begin.
    1. Protocol Videodrone AP Camera Replacement, Camera: step 1, image 1 of 1
      • Power off the drone before proceeding with this repair.
      Ask FixBot
    2. Protocol Videodrone AP Camera Replacement: step 2, image 1 of 1
      • Remove the propeller screws (1 per propeller).
      • You can use the Phillips #0 screwdriver if you don't own the one included with drone.
      Ask FixBot
    3. Protocol Videodrone AP Camera Replacement: step 3, image 1 of 2 Protocol Videodrone AP Camera Replacement: step 3, image 2 of 2
      • Remove the screws holding on the propeller guards using the Phillips #0 screwdriver (2 per propeller guard).
      Ask FixBot
    4. Protocol Videodrone AP Camera Replacement: step 4, image 1 of 2 Protocol Videodrone AP Camera Replacement: step 4, image 2 of 2
      • Using the Phillips #0 screwdriver to remove the eight screws securing the body of the drone.
      Ask FixBot
    5. Protocol Videodrone AP Camera Replacement: step 5, image 1 of 1
      • Remove the case.
      Ask FixBot
    6. Protocol Videodrone AP Camera Replacement: step 6, image 1 of 1
      • Remove the propeller motor screws (3 per motor).
      • The plastic screw housing is attached to the motor.
      Ask FixBot
    7. Protocol Videodrone AP Camera Replacement: step 7, image 1 of 3 Protocol Videodrone AP Camera Replacement: step 7, image 2 of 3 Protocol Videodrone AP Camera Replacement: step 7, image 3 of 3
      • Depress the tab to open the battery housing.
      • Disconnect the battery connectors
      • Remove the battery.
      Ask FixBot
    8. Protocol Videodrone AP Camera Replacement: step 8, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the four circuit board screws.
      • Remove circuit board.
      Ask FixBot
    9. Protocol Videodrone AP Camera Replacement: step 9, image 1 of 2 Protocol Videodrone AP Camera Replacement: step 9, image 2 of 2
      • Remove the four battery housing screws with the Phillips #0 screwdriver.
      • Remove the battery housing to reveal the camera circuit board underneath.
      Ask FixBot
    10. Protocol Videodrone AP Camera Replacement: step 10, image 1 of 1
      • Pull upwards on the strip to remove the camera out of its slot.
      Ask FixBot
    11. Protocol Videodrone AP Camera Replacement: step 11, image 1 of 1
      • Remove camera circuit board from housing.
      • On the main circuit board, desolder the the connection points connecting to camera circuit board.
      • Four wires need to be desoldered. Colours include: Red, white, black and blue.
      • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
      Ask FixBot
Author
with
Karan Paranganat
352 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Fall 2019 Member of IUPUI, Team S2-G2, Harley Fall 2019
IUPUI-HARLEY-F19S2G2
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 65
All Time: 752
