Protocol Vento Wi-Fi Antenna Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
51
All Time:
710
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will demonstrate how to remove and replace the Protocol Vento Wi-Fi antenna.
Tools
    1. Protocol Vento Wi-Fi Antenna Replacement, Battery: step 1, image 1 of 1
      • Grasp the tail end of the drone where the lip of the battery protrudes.
      Ask FixBot
    2. Protocol Vento Wi-Fi Antenna Replacement: step 2, image 1 of 1
      • Pull away from the drone to remove the battery.
      • Do not attempt any repairs or replacements before removing the battery from the drone.
      Ask FixBot
    1. Protocol Vento Wi-Fi Antenna Replacement, Transmitter Board: step 3, image 1 of 1
      • To get into the drone, twelve total screws need to be removed:
      • Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
      • Two 4.5mm Phillips #000 screws at the front of the drone.
      • It is not necessary to remove the four screws on the arms of the drone.
      Ask FixBot
    2. Protocol Vento Wi-Fi Antenna Replacement: step 4, image 1 of 3 Protocol Vento Wi-Fi Antenna Replacement: step 4, image 2 of 3 Protocol Vento Wi-Fi Antenna Replacement: step 4, image 3 of 3
      • Flip the drone over and lift off the top plastic shell of the drone.
      Ask FixBot
    3. Protocol Vento Wi-Fi Antenna Replacement: step 5, image 1 of 2 Protocol Vento Wi-Fi Antenna Replacement: step 5, image 2 of 2
      • Remove the foam adhesive pad located on the Wi-Fi transmitter board.
      Ask FixBot
    4. Protocol Vento Wi-Fi Antenna Replacement: step 6, image 1 of 2 Protocol Vento Wi-Fi Antenna Replacement: step 6, image 2 of 2
      • Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it.
      • Be sure to only apply force to the gold connector and not the black wire attached to it, as the connection between the two is very fragile.
      Ask FixBot
    5. Protocol Vento Wi-Fi Antenna Replacement: step 7, image 1 of 1
      • Remove the two 3.8mm Phillips #000 screws from the Wi-Fi transmitter board.
      • Be careful with the delicate ribbon cable attached to the camera.
      Ask FixBot
    6. Protocol Vento Wi-Fi Antenna Replacement: step 8, image 1 of 1
      • Disconnect the white clip that connects the four colored wires (black, orange, red, blue) to the motherboard.
      • Be sure to pull only on the white clip, as to avoid damaging the wires.
      Ask FixBot
    7. Protocol Vento Wi-Fi Antenna Replacement: step 9, image 1 of 2 Protocol Vento Wi-Fi Antenna Replacement: step 9, image 2 of 2
      • Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop.
      • The black insert acts as a wedge to keep the ribbon cable attached to the board. The wedge needs to be jostled loose before the cable can be removed.
      • Lightly pull the ribbon cable away from the connector.
      Ask FixBot
    1. Protocol Vento Wi-Fi Antenna Replacement, Front Camera: step 10, image 1 of 1
      • Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
      Ask FixBot
    2. Protocol Vento Wi-Fi Antenna Replacement: step 11, image 1 of 3 Protocol Vento Wi-Fi Antenna Replacement: step 11, image 2 of 3 Protocol Vento Wi-Fi Antenna Replacement: step 11, image 3 of 3
      • Lift the camera holder and the camera up and away from the drone.
      Ask FixBot
    1. Protocol Vento Wi-Fi Antenna Replacement, Wi-Fi Antenna: step 12, image 1 of 1
      • Unscrew the four 4.9mm Phillips #000 corner screws that are securing the motherboard’s black base to the drone.
      • It is not necessary to unscrew the motherboard from the black base.
      Ask FixBot
    2. Protocol Vento Wi-Fi Antenna Replacement: step 13, image 1 of 2 Protocol Vento Wi-Fi Antenna Replacement: step 13, image 2 of 2
      • Grasp and pull each of the four drone arms in the direction of their propellers, one at a time, to remove them from the drone.
      Ask FixBot
    3. Protocol Vento Wi-Fi Antenna Replacement: step 14, image 1 of 1
      • Gently pull the motherboard out of the drone.
      • The four arms of the drone will dangle from the motherboard by their cords.
      Ask FixBot
    4. Protocol Vento Wi-Fi Antenna Replacement: step 15, image 1 of 1
      • Pull the black, rectangular shell out of the drone.
      • It is not attached with screws.
      Ask FixBot
    5. Protocol Vento Wi-Fi Antenna Replacement: step 16, image 1 of 2 Protocol Vento Wi-Fi Antenna Replacement: step 16, image 2 of 2
      • Hold the drone’s shell with both hands so that the inside of the shell is facing you.
      • Gently flex the shell outward, so that the two latches (holding the antenna in place) move apart slightly.
      • At the same time, push the antenna from the back of the drone towards you until it releases from the latches.
      Ask FixBot
3 other people completed this guide.
Maria Larcomb
926 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Spring 2018 Member of USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 710
