Up to 20% off select tools
Protocol Vento Propeller Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
10
Past 30 Days:
64
All Time:
2,662
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will demonstrate how to remove and replace one or more propellers on the Protocol Vento drone. You will need the small, silver prying tool that is included in the Protocol Vento drone kit.
    1. Protocol Vento Propeller Replacement, Battery: step 1, image 1 of 1
      • Grasp the tail end of the drone where the lip of the battery protrudes.
      Ask FixBot
    2. Protocol Vento Propeller Replacement: step 2, image 1 of 1
      • Pull away from the drone to remove the battery.
      • Do not attempt any repairs or replacements before removing the battery from the drone.
      Ask FixBot
    1. Protocol Vento Propeller Replacement, Propeller: step 3, image 1 of 1
      • Place a prying tool under the base of the propeller.
      Ask FixBot
    2. Protocol Vento Propeller Replacement: step 4, image 1 of 2 Protocol Vento Propeller Replacement: step 4, image 2 of 2
      • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
      Ask FixBot
5 other people completed this guide.
Author
with
Maria Larcomb
926 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Spring 2018 Member of USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Members
72 Guides authored
1 Guide Comment
Thanks for your help!!
Frank Seifert - Reply Share
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 64
All Time: 2,662
