Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
58
All Time:
558
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will walk you through how to replace the light emitting diodes (LED) on the drone. Minimal tooling is required, but the risk of damaging the drone is greater then many of the other guides if each step is not followed and executed with extra care.
Tools
    1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: step 1, image 1 of 2 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: step 1, image 2 of 2
      • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
      • Take care to place the screws in a safe place to prevent losing them.
      Ask FixBot
    2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: step 2, image 1 of 1
      • Separate the upper and lower housing units by lightly pulling the two housing units apart.
      Ask FixBot
    1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): step 3, image 1 of 1
      • Remove 6mm Phillips #0 screw from the LED strip.
      Ask FixBot
    2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: step 4, image 1 of 1
      • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
      • Take care not to damage the LED strip when removing it from the lower housing.
      Ask FixBot
    3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: step 5, image 1 of 1
      • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
      • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
      Ask FixBot
Matthew Selting
453 Reputation
4 Guides authored
UW Stout, Team S8-G4, Ogden Spring 2018 Member of UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 58
All Time: 558
