Protocol Galileo Stealth Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
58
All Time:
1,279
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through how to safely and effectively remove the battery from your drone. This is a relatively simple process that does not require any tools or prerequisite steps. This guide is not required to charge your drone battery, but may be useful if the battery becomes defective.
    1. Protocol Galileo Stealth Battery Replacement, Battery: step 1, image 1 of 1
      • Locate the door to the battery compartment on the underside of the drone.
      Ask FixBot
    2. Protocol Galileo Stealth Battery Replacement: step 2, image 1 of 1
      • Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
      Ask FixBot
    3. Protocol Galileo Stealth Battery Replacement: step 3, image 1 of 1
      • First pull out the wires located to the side of the battery.
      • Carefully remove the battery from the battery compartment
      • The battery can be a bit difficult to remove, but if the wires are held firmly to the battery, the battery will eventually come out by lightly pulling on the battery and wires simultaneously.
      • The small black and white wire with the white plug will not be connected to the drone, just be sure the plug does not get stuck in the battery compartment and damaged while removing the battery. This is rarely an issue.
      Ask FixBot
    4. Protocol Galileo Stealth Battery Replacement: step 4, image 1 of 1
      • Disconnect the two ends of the wires by lightly pulling them apart.
      Ask FixBot
stephen R masalewicz
273 Reputation
2 Guides authored
UW Stout, Team S8-G4, Ogden Spring 2018 Member of UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Members
72 Guides authored
1 Guide Comment
Please were can buy the battery
odoffin Kehinde - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 58
All Time: 1,279
