Protocol Galileo Pinion Gear Replacement
  1. Protocol Galileo Pinion Gear Replacement, Battery: step 1, image 1 of 1
    • Find door on the underside of drone. Open the door.
    Ask FixBot
  2. Protocol Galileo Pinion Gear Replacement: step 2, image 1 of 2 Protocol Galileo Pinion Gear Replacement: step 2, image 2 of 2
    • Carefully pull out battery, pulling out wires first.
    Ask FixBot
  3. Protocol Galileo Pinion Gear Replacement: step 3, image 1 of 1
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
    Ask FixBot
  4. Protocol Galileo Pinion Gear Replacement, Propeller: step 4, image 1 of 2 Protocol Galileo Pinion Gear Replacement, Propeller: step 4, image 2 of 2
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
    Ask FixBot
  5. Protocol Galileo Pinion Gear Replacement: step 5, image 1 of 1
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
    Ask FixBot
  6. Protocol Galileo Pinion Gear Replacement: step 6, image 1 of 1
    Buy
    Ask FixBot
  7. Protocol Galileo Pinion Gear Replacement: step 7, image 1 of 1
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
    Ask FixBot
  8. Protocol Galileo Pinion Gear Replacement: step 8, image 1 of 2 Protocol Galileo Pinion Gear Replacement: step 8, image 2 of 2
    • Pull off propeller.
    Ask FixBot
  9. Protocol Galileo Pinion Gear Replacement, Top Shell: step 9, image 1 of 3 Protocol Galileo Pinion Gear Replacement, Top Shell: step 9, image 2 of 3 Protocol Galileo Pinion Gear Replacement, Top Shell: step 9, image 3 of 3
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
    Ask FixBot
  10. Protocol Galileo Pinion Gear Replacement: step 10, image 1 of 2 Protocol Galileo Pinion Gear Replacement: step 10, image 2 of 2
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
    Ask FixBot
  11. Protocol Galileo Pinion Gear Replacement: step 11, image 1 of 3 Protocol Galileo Pinion Gear Replacement: step 11, image 2 of 3 Protocol Galileo Pinion Gear Replacement: step 11, image 3 of 3
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
    Ask FixBot
  12. Protocol Galileo Pinion Gear Replacement: step 12, image 1 of 2 Protocol Galileo Pinion Gear Replacement: step 12, image 2 of 2
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
    Ask FixBot
  13. Protocol Galileo Pinion Gear Replacement: step 13, image 1 of 3 Protocol Galileo Pinion Gear Replacement: step 13, image 2 of 3 Protocol Galileo Pinion Gear Replacement: step 13, image 3 of 3
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
    Ask FixBot
  14. Protocol Galileo Pinion Gear Replacement: step 14, image 1 of 1
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
    Ask FixBot
  15. Protocol Galileo Pinion Gear Replacement: step 15, image 1 of 2 Protocol Galileo Pinion Gear Replacement: step 15, image 2 of 2
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
    Ask FixBot
  16. Protocol Galileo Pinion Gear Replacement: step 16, image 1 of 3 Protocol Galileo Pinion Gear Replacement: step 16, image 2 of 3 Protocol Galileo Pinion Gear Replacement: step 16, image 3 of 3
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
    Ask FixBot
  17. Protocol Galileo Pinion Gear Replacement, Pinion Gear: step 17, image 1 of 1
    • Remove the motor assembly from the bottom shell.
    Ask FixBot
  18. Protocol Galileo Pinion Gear Replacement: step 18, image 1 of 2 Protocol Galileo Pinion Gear Replacement: step 18, image 2 of 2
    • Slide the pinion gear off of the motor assembly.
    Ask FixBot
Thomas Ramey
301 Reputation
3 Guides authored
UW Tacoma, Team 2-3, Rose Winter 2017 Member of UW Tacoma, Team 2-3, Rose Winter 2017
UWT-ROSE-W17S2G3
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 515
