Introduction
Go to step 1 ↓If one or more motors on your drone are not responding, this guide will show you how to replace them.
Tools
Tool used on this step:Heavy-Duty Spudger$4.99
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
Remove the two 4mm Philips screws from the motor.
Separate the motor from the plastic motor holder.
1 Guide Comment
what I need to know is where can I buy the plastic motor holder. This would be for a Galileo stealth drone. can someone please help me with this. markkermoyan@gmail.com
