Up to 20% off select tools
Protocol Dronium Two HD Camera Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
91
All Time:
652
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This is how to remove and replace the HD camera on the underside of the drone if necessary. Be careful not to pull on the wires as that may damage them. Removing the landing gear closest to the camera wires will make this job easier. Please use a clean and well lit area, as the screws are small.
    1. Protocol Dronium Two HD Camera Replacement, Landing Gear: step 1, image 1 of 1
      • Turn device off by moving the selector switch to the left.
      Ask FixBot
    2. Protocol Dronium Two HD Camera Replacement: step 2, image 1 of 2 Protocol Dronium Two HD Camera Replacement: step 2, image 2 of 2
      • Place one hand on the drone and carefully remove the landing gear with the other hand.
      • Be gentle as to not break off the studs on the landing gear.
      Ask FixBot
    1. Protocol Dronium Two HD Camera Replacement, HD Camera: step 3, image 1 of 2 Protocol Dronium Two HD Camera Replacement, HD Camera: step 3, image 2 of 2
      • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
      Ask FixBot
    2. Protocol Dronium Two HD Camera Replacement: step 4, image 1 of 2 Protocol Dronium Two HD Camera Replacement: step 4, image 2 of 2
      • Push the battery cover away from the drone and carefully open it up.
      Ask FixBot
    3. Protocol Dronium Two HD Camera Replacement: step 5, image 1 of 2 Protocol Dronium Two HD Camera Replacement: step 5, image 2 of 2
      • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
      Ask FixBot
    4. Protocol Dronium Two HD Camera Replacement: step 6, image 1 of 1
      • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
      Ask FixBot
Author
with
William Tietz
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 91
All Time: 652
