Protocol Dronium III AP Trim Rocker Switch Replacement
  1. Protocol Dronium III AP Trim Rocker Switch Replacement, Trim Rocker Switch: step 1, image 1 of 3 Protocol Dronium III AP Trim Rocker Switch Replacement, Trim Rocker Switch: step 1, image 2 of 3 Protocol Dronium III AP Trim Rocker Switch Replacement, Trim Rocker Switch: step 1, image 3 of 3
    • Remove the four (4) 8.5mm screws from the body of the remote using a JIS #1 screwdriver.
    • Remove the two (2) 4mm screws from the handle using a JIS #1 screwdriver.
    • Open remote body lifting back a full 180 degrees from face.
    Ask FixBot
  2. Protocol Dronium III AP Trim Rocker Switch Replacement: step 2, image 1 of 3 Protocol Dronium III AP Trim Rocker Switch Replacement: step 2, image 2 of 3 Protocol Dronium III AP Trim Rocker Switch Replacement: step 2, image 3 of 3
    • Remove the four (4) 6mm screws attaching the motherboard to body of the controller using a JIS #1 screwdriver
    • Gently lift the motherboard backwards.
    Ask FixBot
  3. Protocol Dronium III AP Trim Rocker Switch Replacement: step 3, image 1 of 3 Protocol Dronium III AP Trim Rocker Switch Replacement: step 3, image 2 of 3 Protocol Dronium III AP Trim Rocker Switch Replacement: step 3, image 3 of 3
    • Remove the trim rocker switch from the controller.
    Ask FixBot
Steven Mooers
401 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Rose Fall 2017 Member of UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 468
