Protocol Dronium III AP Light Bulb Replacement
    1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: step 1, image 1 of 2 Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: step 1, image 2 of 2
      • Ensure the drone is powered off.
      • Press in and lift battery compartment cover.
      • A soft pry tool may be used for easier access.
      Ask FixBot
    2. Protocol Dronium III AP Light Bulb Replacement: step 2, image 1 of 1
      • Remove battery pack from body of drone.
      Ask FixBot
    3. Protocol Dronium III AP Light Bulb Replacement: step 3, image 1 of 2 Protocol Dronium III AP Light Bulb Replacement: step 3, image 2 of 2
      • Disconnect white connectors between the battery pack and drone.
      Ask FixBot
    1. Protocol Dronium III AP Light Bulb Replacement, L.E.D. Bulb(s): step 4, image 1 of 1
      • Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
      Ask FixBot
    2. Protocol Dronium III AP Light Bulb Replacement: step 5, image 1 of 2 Protocol Dronium III AP Light Bulb Replacement: step 5, image 2 of 2
      • Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
      • Remove the Body Cover.
      Ask FixBot
    3. Protocol Dronium III AP Light Bulb Replacement: step 6, image 1 of 2 Protocol Dronium III AP Light Bulb Replacement: step 6, image 2 of 2
      • Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
      • Lift the Motherboard off the mounting position.
      • Do not pull hard on the Motherboard as solder connections are fragile.
      Ask FixBot
    4. Protocol Dronium III AP Light Bulb Replacement: step 7, image 1 of 2 Protocol Dronium III AP Light Bulb Replacement: step 7, image 2 of 2
      • This step contains a tool that can present a potential burn hazard.
      • Prepare and warm up a soldering iron.
      • Position Motherboard so that the L.E.D. bulb solder joints are accessible.
      • Use the soldering iron to melt the solder joints.
      • For more detailed instructions on how to solder, visit out How to Solder and Desolder Connections guide.
      • Remove the L.E.D. bulb from the Motherboard
      Ask FixBot
Steven Mooers
401 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Rose Fall 2017 Member of UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 23
All Time: 441
