Up to 20% off select tools
Protocol Dronium III AP Camera Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
85
All Time:
735
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide explains how to replace the Protocol Dronium III AP Camera.
    1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: step 1, image 1 of 2 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: step 1, image 2 of 2
      • Ensure the drone is powered off.
      • Press in and lift battery compartment cover.
      • A soft pry tool may be used for easier access.
      Ask FixBot
    2. Protocol Dronium III AP Camera Replacement: step 2, image 1 of 1
      • Remove battery pack from body of drone.
      Ask FixBot
    3. Protocol Dronium III AP Camera Replacement: step 3, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 3, image 2 of 2
      • Disconnect white connectors between the battery pack and drone.
      Ask FixBot
    1. Protocol Dronium III AP Camera Replacement, Camera: step 4, image 1 of 1
      • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
      Ask FixBot
    2. Protocol Dronium III AP Camera Replacement: step 5, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 5, image 2 of 2
      • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
      • Remove the Body Cover.
      Ask FixBot
    3. Protocol Dronium III AP Camera Replacement: step 6, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 6, image 2 of 2
      • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
      • Lift the Motherboard off the mounting position.
      • Do not pull hard on the Motherboard as solder connections are fragile.
      Ask FixBot
    4. Protocol Dronium III AP Camera Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the tape covering the camera with the tweezers.
      Ask FixBot
    5. Protocol Dronium III AP Camera Replacement: step 8, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 8, image 2 of 2
      • Remove the plastic holding the ribbon cable connector with the tweezers.
      • Be careful with the ribbon cable, it is easy to damage.
      Ask FixBot
    6. Protocol Dronium III AP Camera Replacement: step 9, image 1 of 1
      • Move the ribbon cable out of the way with the Spuger.
      Ask FixBot
    7. Protocol Dronium III AP Camera Replacement: step 10, image 1 of 2 Protocol Dronium III AP Camera Replacement: step 10, image 2 of 2
      • Remove the camera by gently prying it out of the bracket with the spudger.
      Ask FixBot
Author
with
Steven Mooers
401 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Rose Fall 2017 Member of UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 85
All Time: 735
