ProtoCentre 999 Extruder fan Replacement
    • We want to check the fan is running or not.
    • If you place your hand near your fan, you can understand the fan is running or not.
    Ask FixBot
    • In some case , the fan speed may get reduced. In this case also we want to put new fan. Else the may effect the working of the nozzle.For checking this, GO TO PREPARE
    • PREHEAT the machine
    • After getting preheated, place your hand near fan, if the fan is pulling out less hot air, you has to change the fan.
    Ask FixBot
    • Remove the fan from the nozzle block with the help of allen key.
    • Remove the back cover of the machine.
    • In the 12V supply PCB there will be a connection for extruder fan, remove it. And take the fan out.
    Ask FixBot
    • Change the fan with new fan.
    • Reconnect the fan connection in the 12V supply PCB.
    • Connect the fan in the nozzle block with the help of allen key.
    Ask FixBot
    • After connecting the fan back, check the fan speed with the help of your hand placing near the fan.
    Ask FixBot
abhishek j
1,193 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 225
