Up to 20% off select tools
Proscan Tablet Touch Screen Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
105
All Time:
6,527
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 45 minutes
Difficulty: Moderate
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Proscan Tablet Touch Screen Replacement, Touch Screen: step 1, image 1 of 1
      • Tools necessary for task.
      • Starting from the left to right
      • Metal Spudyer
      • Plastic opening tool
      • Precision tweezer
      • Point pen tool
      • Driver with bit size J0
      Ask FixBot
    2. Proscan Tablet Touch Screen Replacement: step 2, image 1 of 1
      • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
      Ask FixBot
    3. Proscan Tablet Touch Screen Replacement: step 3, image 1 of 1
      • Once you have finished going around the edges of the tablet, look inside.
      Ask FixBot
    4. Proscan Tablet Touch Screen Replacement: step 4, image 1 of 1
      • You will notice two wires still connecting the backing to the computer. These are for the speakers.
      Ask FixBot
    5. Proscan Tablet Touch Screen Replacement: step 5, image 1 of 1
      • You can remove the speakers with your hands to free the backing completely.
      Ask FixBot
    6. Proscan Tablet Touch Screen Replacement: step 6, image 1 of 1
      • Next the following highlighted spots are screws. These screws must be loosened to separate the motherboard and digitizer from the outer glass components. Remember lefty loosely, righty tighty. All screws were placed on a magnet board to ensure they did not roll away
      Ask FixBot
    7. Proscan Tablet Touch Screen Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • There is some tape wire that links the screen to the grey digitizer. This can be gently pulled apart by the tweezers
      Ask FixBot
    8. Proscan Tablet Touch Screen Replacement: step 8, image 1 of 1
      • Next focus on the camera and volume components along the edges highlighted here. The screws have already been taken out, gently pull them off.
      Ask FixBot
    9. Proscan Tablet Touch Screen Replacement: step 9, image 1 of 1
      • Gently lift the green motherboard from the grey digitizer to ensure that all screws have been removed. The only connection remaining should be a tape wire to the battery.
      Ask FixBot
    10. Proscan Tablet Touch Screen Replacement: step 10, image 1 of 1
      • The last step is to remove the grey digitizer from the screen entirely. Note that the blue battery and green motherboard will still be attached, move them as one part
      Ask FixBot
3 other people completed this guide.
Author
with
Cameron Denny
321 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 105
All Time: 6,527
