Up to 20% off select tools
Proscan Tablet Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
84
All Time:
885
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Proscan Tablet Camera Replacement, Camera: step 1, image 1 of 1
      • Tools necessary for task. Starting from the left to right Metal Spudyer Plastic opening tool Precision tweezer Point pen tool Driver with bit size J0
      Ask FixBot
    2. Proscan Tablet Camera Replacement: step 2, image 1 of 1
      • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
      Ask FixBot
    3. Proscan Tablet Camera Replacement: step 3, image 1 of 1
      • Once you have finished going around the edges of the tablet, look inside.
      Ask FixBot
    4. Proscan Tablet Camera Replacement: step 4, image 1 of 1
      • You can directly locate and remove the camera component in the corner. Simply unscrew the piece and gently remove the tape wire.
      Ask FixBot
Author
with
Cameron Denny
321 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 84
All Time: 885
