Up to 20% off select tools
Propeller Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
108
All Time:
801
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Propeller Replacement, Propeller: step 1, image 1 of 2 Propeller Replacement, Propeller: step 1, image 2 of 2
      • Rotate the propeller to locate the propeller set screw.
      Ask FixBot
    2. Propeller Replacement: step 2, image 1 of 2 Propeller Replacement: step 2, image 2 of 2
      • Unscrew the single 4 mm Phillips screw.
      Ask FixBot
    3. Propeller Replacement: step 3, image 1 of 3 Propeller Replacement: step 3, image 2 of 3 Propeller Replacement: step 3, image 3 of 3
      • Slide the propeller up and off the motor assembly.
      Ask FixBot
    4. Propeller Replacement: step 4, image 1 of 3 Propeller Replacement: step 4, image 2 of 3 Propeller Replacement: step 4, image 3 of 3
      • To attach the new propeller, align the hexagonal slot in the propeller base with the keyed motor shaft.
      • Ensure one of the screw holes on the motor shaft aligns with the propeller screw hole.
      • Slide the propeller onto the motor shaft.
      Ask FixBot
    5. Propeller Replacement: step 5, image 1 of 2 Propeller Replacement: step 5, image 2 of 2
      • Finally, fasten the set screw back into the propeller.
      • Congratulations, you have completed this propeller replacement guide! If your drone continues to malfunction, try exploring the motor replacement guide here
      Ask FixBot
Finish Line
Author
with
Adrian Eaton
617 Reputation
4 Guides authored
Cal Poly, Team 70-2, Forte Winter 2015 Member of Cal Poly, Team 70-2, Forte Winter 2015
CPSU-FORTE-W15S70G2
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 108
All Time: 801
