Propel Gyro-X Drive Gears Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
90
All Time:
3,764
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
You may need to replace your helicopter's drive gears if they become damaged or stripped. Replacing the gears will require you to completely disassemble your helicopter, so make sure to place small parts and screws in a safe place to avoid losing them.
Tools
    1. Propel Gyro-X Drive Gears Replacement, Top Propellor Blades: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Stabilizing links are easy to break. Be gentle when prying them off.
      • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
      Ask FixBot
    2. Propel Gyro-X Drive Gears Replacement: step 2, image 1 of 2 Propel Gyro-X Drive Gears Replacement: step 2, image 2 of 2
      • Remove the two 6.0 mm Phillips #00 screws from the rotors.
      Ask FixBot
    3. Propel Gyro-X Drive Gears Replacement: step 3, image 1 of 2 Propel Gyro-X Drive Gears Replacement: step 3, image 2 of 2
      • Pull the rotors away from the mounting brackets.
      Ask FixBot
    1. Propel Gyro-X Drive Gears Replacement, Bottom Propellor Blades: step 4, image 1 of 1
      • Remove the two 5.0 mm Phillips #00 screws from the rotors.
      • The blades will fall off when the screws have been removed.
      Ask FixBot
    1. Propel Gyro-X Drive Gears Replacement, Outer Shell: step 5, image 1 of 1
      • Locate the nubs on either side of the helicopter.
      Ask FixBot
    2. Propel Gyro-X Drive Gears Replacement: step 6, image 1 of 1
      • Pull the body shell off of the nubs on both sides.
      Ask FixBot
    3. Propel Gyro-X Drive Gears Replacement: step 7, image 1 of 2 Propel Gyro-X Drive Gears Replacement: step 7, image 2 of 2
      • Push the front of the nose back towards the tail of the helicopter.
      • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
      Ask FixBot
    1. Propel Gyro-X Drive Gears Replacement, Drive Gears: step 8, image 1 of 1
      • Remove the two 8 mm Phillips #00 screws between the motor casing and the body.
      Ask FixBot
    2. Propel Gyro-X Drive Gears Replacement: step 9, image 1 of 1
      • Remove the 4 mm Phillips #00 screw from the tail.
      Ask FixBot
    3. Propel Gyro-X Drive Gears Replacement: step 10, image 1 of 3 Propel Gyro-X Drive Gears Replacement: step 10, image 2 of 3 Propel Gyro-X Drive Gears Replacement: step 10, image 3 of 3
      • Use your fingers to free the motor casing from the body, by bending the plastic body casing outwards at each of the four nubs.
      • Pull the motor casing upwards from the body.
      • The drive gear will slide out when you lift the motor casing.
      Ask FixBot
2 other people completed this guide.
Jack Jenner
293 Reputation
2 Guides authored
Cal Poly, Team 17-2, Forte Spring 2015 Member of Cal Poly, Team 17-2, Forte Spring 2015
CPSU-FORTE-S15S17G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 90
All Time: 3,764
