Propane Grill Regulator & Hose Replacement
Views: 8.4K
View statistics:
Past 24 Hours:
10
Past 7 Days:
40
Past 30 Days:
163
All Time:
8,422
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Sometimes through typical wear and tear, your grill may not want to start right. If you live in an area where you don't use it year round after a period of time, it doesn't want to start correctly, It could be numerous things. This guide shows the most common isuses that could prevent a grill front starting or running properly, from the battery in the igniter to the propane hose and regulator.
    1. Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: step 1, image 1 of 2 Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: step 1, image 2 of 2
      • Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
      • Breathing in or swallowing propane can harm your health.
      • Turn the knob on the hose counter clockwise to disconnect it from the tank.
      Ask FixBot
    2. Propane Grill Regulator & Hose Replacement: step 2, image 1 of 2 Propane Grill Regulator & Hose Replacement: step 2, image 2 of 2
      • Find the electric igniter on the grill and turn it counter clockwise to reveal one AA battery.
      • Replace the old battery with a new one.
      Ask FixBot
    3. Propane Grill Regulator & Hose Replacement: step 3, image 1 of 1
      • Locate the orifice that connects the base of the grill and the hose to one another.
      • An orifice is a valve commonly found on gas powered home products. This allows the gas to pass through from the source (i.e the propane tank) and burn properly.
      • Conncected to the orifice should be a nut. Use the crescent wrench to turn the nut counter clockwise and remove the hose from the base.
      Ask FixBot
    4. Propane Grill Regulator & Hose Replacement: step 4, image 1 of 2 Propane Grill Regulator & Hose Replacement: step 4, image 2 of 2
      • Begin hand tightening the new hose to the nut that is connected to the orifice.
      • If you over tighten the bolt or do not hand tighten it first, you could cross thread the orifice and create more problems for the grill.
      • Once it has been adequately hand tightened use the crescent wrench to finish securing it to the orifice.
      Ask FixBot
3 other people completed this guide.
Evan Jureski
146 Reputation
1 Guide authored
2 Guide Comments
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Rob Fillion - Reply Share
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
Past 24 Hours: 10
Past 7 Days: 40
Past 30 Days: 163
All Time: 8,422
