Up to 20% off select tools
ProntoTec Axius Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
83
All Time:
878
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Handheld devices such as this tablet are very commonly dropped. Even dropping your device small heights can result in shattering or breaking the screen. This guide demonstrates how to remove other components inside the device to access the screen for removal and replacement.
    1. ProntoTec Axius Screen Replacement, Screen: step 1, image 1 of 1
      • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
      • Place the tablet face-up on a flat table
      Ask FixBot
    2. ProntoTec Axius Screen Replacement: step 2, image 1 of 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Ask FixBot
    3. ProntoTec Axius Screen Replacement: step 3, image 1 of 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Ask FixBot
    4. ProntoTec Axius Screen Replacement: step 4, image 1 of 1
      • Remove all of the yellow tape that is on the device with the spudger.
      • Be careful not to cut any wires that are under the tapes.
      Ask FixBot
    5. ProntoTec Axius Screen Replacement: step 5, image 1 of 2 ProntoTec Axius Screen Replacement: step 5, image 2 of 2
      • Use the flat end of the spudger to gently pry the battery from the back of the screen.
      Ask FixBot
    6. ProntoTec Axius Screen Replacement: step 6, image 1 of 2 ProntoTec Axius Screen Replacement: step 6, image 2 of 2
      • Use a spudger to lift all the ribbon cable clamps
      • Detach all three ribbon cables from the clamps
      Ask FixBot
    7. ProntoTec Axius Screen Replacement: step 7, image 1 of 3 ProntoTec Axius Screen Replacement: step 7, image 2 of 3 ProntoTec Axius Screen Replacement: step 7, image 3 of 3
      • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
      Ask FixBot
    8. ProntoTec Axius Screen Replacement: step 8, image 1 of 3 ProntoTec Axius Screen Replacement: step 8, image 2 of 3 ProntoTec Axius Screen Replacement: step 8, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
      • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
      Ask FixBot
    9. ProntoTec Axius Screen Replacement: step 9, image 1 of 1
      • Remove the orange tab from the back of the screen as shown in the picture
      Ask FixBot
    10. ProntoTec Axius Screen Replacement: step 10, image 1 of 2 ProntoTec Axius Screen Replacement: step 10, image 2 of 2
      • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
      Ask FixBot
Author
with
Antonio Irons
441 Reputation
4 Guides authored
UMass Dartmouth, Team 5-3, Martin Fall 2016 Member of UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 83
All Time: 878
