Up to 20% off select tools
ProntoTec Axius Motherboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
88
All Time:
945
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
All electrical components of the ProntoTec Axius tablet are connected to the motherboard. Water damage, dropping, and any other physical damage can cause the motherboard to short or malfunction; rendering the device unusable. This guide will highlight how to disconnect the motherboard from the other components of the device for replacement.
    1. ProntoTec Axius Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Ask FixBot
    2. ProntoTec Axius Motherboard Replacement: step 2, image 1 of 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Ask FixBot
    3. ProntoTec Axius Motherboard Replacement: step 3, image 1 of 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Ask FixBot
    4. ProntoTec Axius Motherboard Replacement: step 4, image 1 of 2 ProntoTec Axius Motherboard Replacement: step 4, image 2 of 2
      • Remove only the yellow tape that touches the motherboard
      • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
      Ask FixBot
    5. ProntoTec Axius Motherboard Replacement: step 5, image 1 of 3 ProntoTec Axius Motherboard Replacement: step 5, image 2 of 3 ProntoTec Axius Motherboard Replacement: step 5, image 3 of 3
      • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
      • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
      Ask FixBot
    6. ProntoTec Axius Motherboard Replacement: step 6, image 1 of 2 ProntoTec Axius Motherboard Replacement: step 6, image 2 of 2
      • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
      • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
      • Use pliers to pull the wire from the board
      Ask FixBot
    7. ProntoTec Axius Motherboard Replacement: step 7, image 1 of 2 ProntoTec Axius Motherboard Replacement: step 7, image 2 of 2
      • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
      Ask FixBot
    8. ProntoTec Axius Motherboard Replacement: step 8, image 1 of 3 ProntoTec Axius Motherboard Replacement: step 8, image 2 of 3 ProntoTec Axius Motherboard Replacement: step 8, image 3 of 3
      • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
      • Gently pull and remove the ribbon cables from the motherboard
      Ask FixBot
    9. ProntoTec Axius Motherboard Replacement: step 9, image 1 of 2 ProntoTec Axius Motherboard Replacement: step 9, image 2 of 2
      • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
      Ask FixBot
Author
with
Estelle Hatem
156 Reputation
1 Guide authored
UMass Dartmouth, Team 5-3, Martin Fall 2016 Member of UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 88
All Time: 945
