Promowide SP1790 Charging Port Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
96
All Time:
1,591
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 6 - 9 minutes
Difficulty: Easy
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will instruct you on how to replace the charging port in this speaker. This will ensure the performance of the device's wireless function.
Parts
Tools
    1. Promowide SP1790 Charging Port Replacement, Battery Wire: step 1, image 1 of 1
      • Locate the six screws on the back of the speaker.
      Ask FixBot
    2. Promowide SP1790 Charging Port Replacement: step 2, image 1 of 1
      • Unscrew each of the six screws, then set them aside.
      Ask FixBot
    3. Promowide SP1790 Charging Port Replacement: step 3, image 1 of 1
      • Gently remove the back cover of the speaker.
      Ask FixBot
    4. Promowide SP1790 Charging Port Replacement: step 4, image 1 of 1
      • Place the speaker upside down.
      • Remove the battery cover located in the center of the speaker.
      Ask FixBot
    5. Promowide SP1790 Charging Port Replacement: step 5, image 1 of 1
      • Locate and remove the four screws under each of the pads near the power socket.
      Ask FixBot
    6. Promowide SP1790 Charging Port Replacement: step 6, image 1 of 1
      • Gently remove the bottom.
      • Do NOT pull out or damage wires.
      Ask FixBot
    7. Promowide SP1790 Charging Port Replacement: step 7, image 1 of 1
      • Remove the single motherboard screw.
      Ask FixBot
    8. Promowide SP1790 Charging Port Replacement: step 8, image 1 of 1
      • Remove both of the screws holding the power socket to the bottom chassis.
      Ask FixBot
    9. Promowide SP1790 Charging Port Replacement: step 9, image 1 of 1
      • Desolder and remove the old wire.
      • Insert the new wire and solder it into place.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 96
All Time: 1,591
