Up to 20% off select tools
Projector NEC VT660 Disassembly
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
68
All Time:
670
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Projector NEC VT660 Disassembly, Remove lamp cover: step 1, image 1 of 2 Projector NEC VT660 Disassembly, Remove lamp cover: step 1, image 2 of 2
      • Unscrew the screw and remove the cover.
      Ask FixBot
    2. Projector NEC VT660 Disassembly, Remove lamp: step 2, image 1 of 2 Projector NEC VT660 Disassembly, Remove lamp: step 2, image 2 of 2
      • Unscrew the two screws that are holding the lamp in place.
      • Pull the lamp out.
      Ask FixBot
    3. Projector NEC VT660 Disassembly, Housing disassembly: step 3, image 1 of 3 Projector NEC VT660 Disassembly, Housing disassembly: step 3, image 2 of 3 Projector NEC VT660 Disassembly, Housing disassembly: step 3, image 3 of 3
      • Remove 5 screws from the bottom.
      • Remove 1 screw from the back.
      • Slowly lift the upper housing and disconnect the connector.
      • Do not lift the upper housing too quickly as it could damage the connector cable.
      Ask FixBot
    4. Projector NEC VT660 Disassembly, Removing fan: step 4, image 1 of 3 Projector NEC VT660 Disassembly, Removing fan: step 4, image 2 of 3 Projector NEC VT660 Disassembly, Removing fan: step 4, image 3 of 3
      • After removing the upper housing. Turn the projector to see the fan.
      • Unscrew two screws from each side of the fan holder.
      • Remove the fan from holder by unscrewing the two screws.
      • Carefully take out the fan. Keep an eye on the wires that go through the holder.
      Ask FixBot
Attached Documents
Author
with
Klemen Hodžić
764 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 68
All Time: 670
