Programmeer het automatisch opstarten van je pc
    • Wanneer je je computer opstart, druk je op de Del- of F2-toets, afhankelijk van je moederbord
  1. Programmeer het automatisch opstarten van je pc, Navigate to the Alimentation tab: step 2, image 1 of 1
    • With the arrow keys, move the header towards the Alimentation tab.
  2. Programmeer het automatisch opstarten van je pc, APM Configuration: step 3, image 1 of 1
    • Once again with the arrow keys, higlight the APM Configuration option and press Enter.
  3. Programmeer het automatisch opstarten van je pc, RTC Configuration: step 4, image 1 of 3 Programmeer het automatisch opstarten van je pc, RTC Configuration: step 4, image 2 of 3 Programmeer het automatisch opstarten van je pc, RTC Configuration: step 4, image 3 of 3
    • Navigate to the Power On by RTC alarm and press Enter. Then, select the Enable option.
    • The RTC Alarm Date option allows you to set the number of days for when your computer will be able to start on its own.
    • Specify the desired hour for startup.
    • Press the F10 key and confirm by pressing Enter when Yes is highlighted. Your pc will start automatically at the specified time and number of days that were previously specified.
Als je BIOS deze optie niet heeft: Softwareoplossingen zijn beschikbaar en eenvoudig in te stellen
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Amrounassim
550 Reputation
1 Guide authored
1 Guide Comment
To automatically start up a PC at a specific time, you can set up a scheduled task in the Windows Task Scheduler. Here are the steps:
Open the Task Scheduler by searching for it in the Start menu.
Click on "Create Basic Task" in the right-hand panel.
Give the task a name and description, and click "Next".
Select "Daily" as the trigger and click "Next".
Set the date and time when you want the computer to automatically start up, and click "Next".
Select "Start a program" as the action, and click "Next".
In the "Program/script" field, type "C:\Windows\System32\cmd.exe". In the "Add arguments (optional)" field, type "/c start".
Click "Next" and then "Finish".
The PC will now automatically start up at the specified time. Note that the PC must be in sleep or hibernate mode for this to work, not powered off.
Click here more information: https://crecentech.com/
Ethan Klein - Reply Share
Past 24 Hours: 6
Past 7 Days: 53
Past 30 Days: 228
All Time: 7,485
