Up to 20% off select tools
ProfiMixx 44 Disassembly
Views: 2.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
25
Past 30 Days:
105
All Time:
2,284
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
In case of broken lugs or screw holders, the two housing parts can be glued together. It is important to check that you have assembled everything correctly before gluing.
    1. ProfiMixx 44 Disassembly, Removing the scrapers: step 1, image 1 of 3 ProfiMixx 44 Disassembly, Removing the scrapers: step 1, image 2 of 3 ProfiMixx 44 Disassembly, Removing the scrapers: step 1, image 3 of 3
      • Removing the five (TR15) scrapers
      Ask FixBot
    2. ProfiMixx 44 Disassembly, Removing the housing: step 2, image 1 of 2 ProfiMixx 44 Disassembly, Removing the housing: step 2, image 2 of 2
      • Removing the first part of the housing
      • Removing the rotary wheel, important pay attention to the black component so that the nose in does not break off (green mark).
      • Removing the second part of the housing
      Ask FixBot
    3. ProfiMixx 44 Disassembly, Assembly of the housing I: step 3, image 1 of 3 ProfiMixx 44 Disassembly, Assembly of the housing I: step 3, image 2 of 3 ProfiMixx 44 Disassembly, Assembly of the housing I: step 3, image 3 of 3
      • Make sure that the green marked elements are in the right place in both housings, the red element is only available once.
      • Make sure that the two strands run as marked in blue.
      • The white element must be in the rear position. (marked in orange)
      Ask FixBot
    4. ProfiMixx 44 Disassembly, Assembly of the housing II: step 4, image 1 of 3 ProfiMixx 44 Disassembly, Assembly of the housing II: step 4, image 2 of 3 ProfiMixx 44 Disassembly, Assembly of the housing II: step 4, image 3 of 3
      • Lift the motor-gearbox-unit a little bit upwards so that you can insert the black element with the nose into the hole of the white element. (marked in green)
      • Insert the nose of the black element into the hole of the rotary switch, making sure it is oriented as shown.
      • Gently move the rotary switch so that it fits into the slot in the housing. (marked in blue)
      • Then you can tighten the upper housing part with the five screws (TR15).
      Ask FixBot
Finish Line
Author
with
Justus Klingler
531 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 105
All Time: 2,284
