Up to 20% off select tools
Professional Series PS77401 Shell Removal
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
15
Past 30 Days:
83
All Time:
1,424
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to safely remove the outer shell of the toaster. Note that the outer shell is not the chassis.
    1. Professional Series PS77401 Shell Removal, Shell: step 1, image 1 of 1
      • Make sure that the toaster is unplugged before attempting any sort of disassembly!
      Ask FixBot
    2. Professional Series PS77401 Shell Removal: step 2, image 1 of 2 Professional Series PS77401 Shell Removal: step 2, image 2 of 2
      • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
      • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
      Ask FixBot
    3. Professional Series PS77401 Shell Removal: step 3, image 1 of 3 Professional Series PS77401 Shell Removal: step 3, image 2 of 3 Professional Series PS77401 Shell Removal: step 3, image 3 of 3
      • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
      • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
      • The outer shell should now only be connected by its internal wiring.
      Ask FixBot
    4. Professional Series PS77401 Shell Removal: step 4, image 1 of 2 Professional Series PS77401 Shell Removal: step 4, image 2 of 2
      • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
      • The shell should now be completely separated from the rest of the toaster.
      Ask FixBot
Author
with
Zachary
267 Reputation
2 Guides authored
Cal Poly, Team 10-36, Maness Winter 2014 Member of Cal Poly, Team 10-36, Maness Winter 2014
CPSU-MANESS-W14S10G36
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 83
All Time: 1,424
