Processor of why! Replace W253EU
    1. Processor of why! Replace W253EU, Battery from why! Remove W253EU: step 1, image 1 of 3 Processor of why! Replace W253EU, Battery from why! Remove W253EU: step 1, image 2 of 3 Processor of why! Replace W253EU, Battery from why! Remove W253EU: step 1, image 3 of 3
      • Turn off the computer.
      • Before each operation it is important to start with the removal of the accumulator.
      • Take the slide unlocked into position, remove the battery.
      Ask FixBot
    1. Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: step 2, image 1 of 2 Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: step 2, image 2 of 2
      • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
      Ask FixBot
    2. Processor of why! Replace W253EU: step 3, image 1 of 3 Processor of why! Replace W253EU: step 3, image 2 of 3 Processor of why! Replace W253EU: step 3, image 3 of 3
      • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
      • Now lift the cover carefully.
      • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
      Ask FixBot
    3. Processor of why! Replace W253EU: step 4, image 1 of 1
      • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
      Ask FixBot
    1. Processor of why! Replace W253EU, processor: step 5, image 1 of 3 Processor of why! Replace W253EU, processor: step 5, image 2 of 3 Processor of why! Replace W253EU, processor: step 5, image 3 of 3
      • Using the Phillips # 1 screwdriver, unscrew the 3 mounting screws of the processor heat sink.
      • Note position of marker triangle as this will determine the positioning of the processor during replacement.
      • Unlock the coupling system of the processor with a classic screwdriver.
      • Make sure that you do not remove the heat-dissipating paste between the processor and the heat sink, as this is the only way to ensure that the processor is properly cooled.
      Ask FixBot
    2. Processor of why! Replace W253EU: step 6, image 1 of 3 Processor of why! Replace W253EU: step 6, image 2 of 3 Processor of why! Replace W253EU: step 6, image 3 of 3
      • Carefully disconnect the processor from its holder.
      • Now place the processor aside, taking into account the position of the triangle.
      Ask FixBot
For reassembly, follow the instructions in the reverse order
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 107
All Time: 974
