Up to 20% off select tools
ProScan PLT7223G Motherboard Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
77
All Time:
2,159
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your device isn't working and other troubleshooting methods have failed, or a component of the motherboard has failed, use this guide to replace the motherboard and make your device functional again.
    1. ProScan PLT7223G Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
      Ask FixBot
    2. ProScan PLT7223G Motherboard Replacement: step 2, image 1 of 1
      • Use the blue opening tool to pry the tablet open.
      Ask FixBot
    3. ProScan PLT7223G Motherboard Replacement: step 3, image 1 of 2 ProScan PLT7223G Motherboard Replacement: step 3, image 2 of 2
      • Remove all yellow tape from the motherboard.
      Ask FixBot
    4. ProScan PLT7223G Motherboard Replacement: step 4, image 1 of 3 ProScan PLT7223G Motherboard Replacement: step 4, image 2 of 3 ProScan PLT7223G Motherboard Replacement: step 4, image 3 of 3
      • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
      • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
      Ask FixBot
    5. ProScan PLT7223G Motherboard Replacement: step 5, image 1 of 3 ProScan PLT7223G Motherboard Replacement: step 5, image 2 of 3 ProScan PLT7223G Motherboard Replacement: step 5, image 3 of 3
      • Lift all three ZIF connectors to disconnect the ribbon wire.
      Ask FixBot
    6. ProScan PLT7223G Motherboard Replacement: step 6, image 1 of 1
      • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
      Ask FixBot
    7. ProScan PLT7223G Motherboard Replacement: step 7, image 1 of 1
      • Lift the motherboard off the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Daniel Hernandez
327 Reputation
1 Guide authored
1 Guide Comment
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
rainbowsend14 - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 77
All Time: 2,159
