Up to 20% off select tools
ProScan PLT7050 Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
87
All Time:
666
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is the camera replacement guide. If you find the camera of the ProScan PLT 7050 is broken, follow these steps to replace the camera.
    1. ProScan PLT7050 Camera Replacement, Open Device: step 1, image 1 of 1
      • Make sure device is unplugged and turned off while working on the device.
      • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
      Ask FixBot
    2. ProScan PLT7050 Camera Replacement: step 2, image 1 of 1
      • Use the plastic opening tools to pry the back of the tablet open.
      • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
      • May be helpful if you start by the microSD slot.
      Ask FixBot
    1. ProScan PLT7050 Camera Replacement, Camera: step 3, image 1 of 1
      • Remove the black tape carefully.
      Ask FixBot
    2. ProScan PLT7050 Camera Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to open the ZIF connector tab to release the camera's ribbon cable.
      Ask FixBot
    3. ProScan PLT7050 Camera Replacement: step 5, image 1 of 1
      • Remove the camera's ribbon cable.
      Ask FixBot
Author
with
Valerie Landguth
320 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 87
All Time: 666
