Up to 20% off select tools
ProScan PLT7050 Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
100
All Time:
1,716
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This is the battery replacement guide for the Proscan PLT 7050. If you find the need to replace the battery, please follow these steps.
    1. ProScan PLT7050 Battery Replacement, Open Device: step 1, image 1 of 1
      • Make sure device is unplugged and turned off while working on the device.
      • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
      Ask FixBot
    2. ProScan PLT7050 Battery Replacement: step 2, image 1 of 1
      • Use the plastic opening tools to pry the back of the tablet open.
      • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
      • May be helpful if you start by the microSD slot.
      Ask FixBot
    1. ProScan PLT7050 Battery Replacement, Battery: step 3, image 1 of 2 ProScan PLT7050 Battery Replacement, Battery: step 3, image 2 of 2
      • Use the soldering tool to remove the wires from the motherboard. (Black and Red)
      • The soldering tool is hot.
      • Take note of where the wires are located.
      Ask FixBot
    2. ProScan PLT7050 Battery Replacement: step 4, image 1 of 2 ProScan PLT7050 Battery Replacement: step 4, image 2 of 2
      • Remove the black tape from the battery.
      • Remove the three pieces of yellow tape from the battery.
      Ask FixBot
    3. ProScan PLT7050 Battery Replacement: step 5, image 1 of 1
      • Use the plastic opening tool to pry the battery from the device as it is attached by an adhesive.
      • Do not proceed if corrosion and/or swelling of the battery is visible.
      Ask FixBot
4 other people completed this guide.
Author
with
Jazmine Jackson
284 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 100
All Time: 1,716
