Princess Compact Blender Rubber Gasket Replacement
    1. Princess Compact Blender Rubber Gasket Replacement, Rubber Gasket: step 1, image 1 of 1
      • Lift the glass container of the motor
      • The motor is the bottom part of the blender
      • If your blender has recently been used, you may want to clean it before taking it apart
      Ask FixBot
    2. Princess Compact Blender Rubber Gasket Replacement: step 2, image 1 of 2 Princess Compact Blender Rubber Gasket Replacement: step 2, image 2 of 2
      • Unscrew the base from the glass container. The right direction is indicated by the red arrow.
      • The base is the part whereon the blades are attached
      Ask FixBot
    3. Princess Compact Blender Rubber Gasket Replacement: step 3, image 1 of 1
      • Lift metal blades with the metal hood out of the base
      • Watch out for sharp blades or wear gloves
      • Large rubber ring may fall out of the base, this is no problem, just put it back in place
      Ask FixBot
    4. Princess Compact Blender Rubber Gasket Replacement: step 4, image 1 of 2 Princess Compact Blender Rubber Gasket Replacement: step 4, image 2 of 2
      • Take the cutting blades in one hand and the black, plastic connector part in the other
      • This is where you could use the gloves
      • Unscrew the latter together with the screw-nut from the axis by twisting
      • If necessary, apply a little force to slightly pull it out
      • To unscrew, you have to twist right. The “righty tighty, lefty loosy-principle” does not apply here
      Ask FixBot
    5. Princess Compact Blender Rubber Gasket Replacement: step 5, image 1 of 1
      • Gently slide off the hood and lower, small metal protective ring from the axis and don’t lose the rubber ring!
      Ask FixBot
    6. Princess Compact Blender Rubber Gasket Replacement: step 6, image 1 of 2 Princess Compact Blender Rubber Gasket Replacement: step 6, image 2 of 2
      • Slide the broken ring off the axis
      • Replace the broken ring for a new one
      Ask FixBot
    7. Princess Compact Blender Rubber Gasket Replacement: step 7, image 1 of 3 Princess Compact Blender Rubber Gasket Replacement: step 7, image 2 of 3 Princess Compact Blender Rubber Gasket Replacement: step 7, image 3 of 3
      • Slide the remaining parts back on the axis in the following order:
      • Metal hood
      • Small metal protective ring
      • Black plastic connector
      • Screw back the screw-nut on the thread with the pliers to fasten the assembly
      • Put the blade-assembly back in the base
      Ask FixBot
    8. Princess Compact Blender Rubber Gasket Replacement: step 8, image 1 of 3 Princess Compact Blender Rubber Gasket Replacement: step 8, image 2 of 3 Princess Compact Blender Rubber Gasket Replacement: step 8, image 3 of 3
      • Twist the base back onto the glass container
      • Put the glass container on the stand (bottom part of the blender, containing the motor)
      • Start making your smoothie!
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 74
All Time: 4,169
