Presto PopLite 04820 Disassembly
    1. Presto PopLite 04820 Disassembly, Popcorn Maker: step 1, image 1 of 1
      • Lift the clear top, removing it from the machine.
      Ask FixBot
    2. Presto PopLite 04820 Disassembly: step 2, image 1 of 1
      • Turn the machine upside down, exposing the screws on the bottom.
      Ask FixBot
    3. Presto PopLite 04820 Disassembly: step 3, image 1 of 3 Presto PopLite 04820 Disassembly: step 3, image 2 of 3 Presto PopLite 04820 Disassembly: step 3, image 3 of 3
      • Remove the three Phillips screws that secure the base plate.
      Ask FixBot
    4. Presto PopLite 04820 Disassembly: step 4, image 1 of 2 Presto PopLite 04820 Disassembly: step 4, image 2 of 2
      • Remove the base plate.
      Ask FixBot
    5. Presto PopLite 04820 Disassembly: step 5, image 1 of 2 Presto PopLite 04820 Disassembly: step 5, image 2 of 2
      • Remove the two Phillips screws securing the main outlet cord.
      Ask FixBot
    6. Presto PopLite 04820 Disassembly: step 6, image 1 of 1
      • Remove the main apparatus from the inside of the popcorn machine body.
      Ask FixBot
    7. Presto PopLite 04820 Disassembly: step 7, image 1 of 2 Presto PopLite 04820 Disassembly: step 7, image 2 of 2
      • Begin unscrewing the four screws holding the black motor to the heating element.
      Ask FixBot
    8. Presto PopLite 04820 Disassembly: step 8, image 1 of 3 Presto PopLite 04820 Disassembly: step 8, image 2 of 3 Presto PopLite 04820 Disassembly: step 8, image 3 of 3
      • Lift the motor off of the heating plate, exposing the wires connecting the two.
      • The motor powers the fan, marked by the arrow.
      Ask FixBot
    9. Presto PopLite 04820 Disassembly: step 9, image 1 of 1
      • After disassembling the Poplite, you can see the interworking of the device.
      • Once the product is plugged into the wall, there is always voltage circulating the device.
      • When the device is plugged in, the heating element turns on automatically as well as the motor that powers the fan, allowing air to circulate through the device, allowing the heating element to focus on popping the popcorn.
      Ask FixBot
    10. Presto PopLite 04820 Disassembly: step 10, image 1 of 1
      • Attached is the Schematic for the Presto Poplite.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 560
