Up to 20% off select tools
Presto 0282202 Disassembly
Views: 2.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
28
Past 30 Days:
109
All Time:
2,239
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
These instructions tell you how to take apart the Presto coffee maker and recover pieces such as two 4349806 Thermal Switches, a small heating wire, and some short wires with spade connectors. The deconstruction guide is easy to follow and only two tools are recommended, a Phillips #2 screwdriver and needle-nose pliers. The only hazard is to be careful of thermal paste when removing the Thermal Switches.
Featured Document
Preview of the first page of this document
Presto 02822 Circuit
Log in to view the full document
Log In
    1. Presto 0282202 Disassembly, Presto 0282202 Disassembly: step 1, image 1 of 3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: step 1, image 2 of 3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: step 1, image 3 of 3
      • Using the Phillips #2 screwdriver, remove the bottom two 25 mm screws off of the coffee percolator.
      • Lighty remove the bottom of the coffee percolator.
      • The wires will keep the two pieces connected.
      Ask FixBot
    2. Presto 0282202 Disassembly: step 2, image 1 of 3 Presto 0282202 Disassembly: step 2, image 2 of 3 Presto 0282202 Disassembly: step 2, image 3 of 3
      • Using the Phillips #2 screwdriver, remove the center 10.8 mm screw holding in the metal strip.
      • Take off the metal strip.
      Ask FixBot
    3. Presto 0282202 Disassembly: step 3, image 1 of 3 Presto 0282202 Disassembly: step 3, image 2 of 3 Presto 0282202 Disassembly: step 3, image 3 of 3
      • Lightly remove the right (bottom facing) thermal switch from its thermal paste.
      • Be careful as the thermal paste can be quite adhesive.
      • Using your small needle-nose pliers, take off the spade connectors connected to the thermal switch.
      • The easiest way to do this is to hold the thermal switch end with the pliers and tug the spade connector off.
      Ask FixBot
    4. Presto 0282202 Disassembly: step 4, image 1 of 3 Presto 0282202 Disassembly: step 4, image 2 of 3 Presto 0282202 Disassembly: step 4, image 3 of 3
      • Lightly remove the left (side facing) thermal switch from its thermal paste.
      Ask FixBot
    5. Presto 0282202 Disassembly: step 5, image 1 of 3 Presto 0282202 Disassembly: step 5, image 2 of 3 Presto 0282202 Disassembly: step 5, image 3 of 3
      • Remove the two spade connectors connected to the heating element.
      • The easiest way to do this is to hold the heating element end with the pliers and tug the spade connector off.
      Ask FixBot
    6. Presto 0282202 Disassembly: step 6, image 1 of 3 Presto 0282202 Disassembly: step 6, image 2 of 3 Presto 0282202 Disassembly: step 6, image 3 of 3
      • Remove the two spade connectors connected to the power connector.
      • The easiest way to do this is to hold the power connector end with the pliers and tug the spade connector off.
      • The final wire removed contains the small heating wire (the thick braided wire) and the signal light.
      Ask FixBot
3 other people completed this guide.
Attached Documents
Author
with
Alexander Koppel
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 109
All Time: 2,239
