Up to 20% off select tools
Presidential Footrest Disassembly
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
91
All Time:
513
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Presidential Footrest Disassembly, Step 1: step 1, image 1 of 1
      • Be sure footrest is on a surface that wont scratch the bottom.
      • Remove the 9 screws on the plastic cover.
      • The Orange circle is the screw that holds the bracket in place . this screw does have a bushing on it DO NOT LOSE IT.
      • Cut zip tie on cable bundle .
      Ask FixBot
    2. Presidential Footrest Disassembly, Step 2: step 2, image 1 of 1
      • Tilt Footrest forward and remove 3 Bottom screws.
      Ask FixBot
    3. Presidential Footrest Disassembly, Step 3: step 3, image 1 of 1
      • Remove screws on left and right wheel and remove wheels from assembly .
      • Be sure to put wheels in safe place to avoid any damage.
      Ask FixBot
    4. Presidential Footrest Disassembly, Complete: step 4, image 1 of 1
      • WHEN PULLING OFF THE COVER THE CABLE BUNDLE WILL NEED TO BE THREADED THROUGH THE CUT OUT ON THE COVER. DO NOT FORCE IT. THIS MAY RESULT IN DAMAGING THE CONNECTORS .
      • You're done ! from here you have complete access to extend mechanism and valve.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. DON'T FORGET TO REPLACE ANY CUT ZIP TIES
Author
with
Nick
2,764 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 91
All Time: 513
