Up to 20% off select tools
Prep Black Wire
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
97
All Time:
1,149
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Prep Black Wire
Parts
Tools
Introduction
Go to step 1 ↓
How to prep a black wire for XYZ job.
    1. Prep Black Wire, Wire: step 1, image 1 of 1
      • Locate QCPN#10669 which is a black hookup wire.
      Ask FixBot
    2. Prep Black Wire: step 2, image 1 of 3 Prep Black Wire: step 2, image 2 of 3 Prep Black Wire: step 2, image 3 of 3
      • Measure out a 10cm length of wire.
      • Use a pair of flash cutters to carefully cut through the wire.
      • Caution: the wire must be no longer than 10.5cm and no shorter than 9.5cm in length.
      Ask FixBot
    3. Prep Black Wire: step 3, image 1 of 1
      • Your wire should look like this now. #testedit
      Ask FixBot
    4. Prep Black Wire: step 4, image 1 of 2 Prep Black Wire: step 4, image 2 of 2
      • Measure 20mm from either end of the wire.
      • With the flash cutters remove the instulation that is covering the wire.
      • Be careful not to cut to deep because you will damage the wire strands inside.
      Ask FixBot
    5. Prep Black Wire: step 5, image 1 of 2 Prep Black Wire: step 5, image 2 of 2
      • Measure 10mm from the other side of the wire.
      • Remove the insulation from the wire with a pair of flash cutters.
      Ask FixBot
    6. Prep Black Wire: step 6, image 1 of 1
      • Your finished wire should now look like this.
      • Remember to twist of the ends of the wire with your fingers so that the wire strands are not loose.
      Ask FixBot
You are finished.
6 other people completed this guide.
Author
with
Russell Frampton
356 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 97
All Time: 1,149
