Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Powertrain Unit Removal
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
53
Past 30 Days:
199
All Time:
2,992
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Very difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The engine block is removed from the bottom of the vehicle.
      • Place the vehicle on a car lift. We will need to raise and lower the vehicle several times.
      Ask FixBot
      • Disconnect the cooling hoses and let as much fluid as possible drain out.
      Ask FixBot
      • Place a collection pan under the transmission.
      • Remove the filler plug.
      • Loosen the transmission drain plug.
      • Allow the oil to drain.
      Ask FixBot
      • In France, only a certified professional is authorized to handle refrigerant fluids. This operation must therefore be performed by a professional who has the necessary equipment and machinery.
      Ask FixBot
      • Air filter housing outlet duct
      • Exhaust muffler
      • Torque strut
      Ask FixBot
      • Gearbox breather hose
      • Clutch line
      Ask FixBot
      • Move the wiring harness and ground wire located in the rear right wheel well.
      Ask FixBot
      • Unscrew the following items
      Ask FixBot
      • Wiring harness
      • Hoses
      Ask FixBot
      • Disconnect the following cables
      Ask FixBot
      • Some vehicles do not appear to be factory-equipped with this cooling fan.
      • Remove the following screws
      Ask FixBot
      • Fuel vapor absorber
      • Fuel supply line
      Ask FixBot
      • Remove the 2 diagonal screws from the rear axle crossmember.
      • Position the rear crossmember removal and installation tool in place of these two screws.
      • Slowly loosen the two nuts on the threaded rods of the removal and installation tool to slowly lower the rear axle crossmember.
      Ask FixBot
      • Use the necessary items and tools to support the engine block.
      Ask FixBot
      • Release the lower transmission and engine mounts.
      • Slowly raise the vehicle to lower the engine block.
      • Remove the transmission and engine silent blocks.
      • Position the engine support tools in place of the silent blocks.
      • Raise the vehicle.
      • Remove the support from under the engine block.
      Ask FixBot
      • Perform the necessary operations
      Ask FixBot
      Ask FixBot
      • Disconnect the following hoses
      Ask FixBot
      • The air conditioning circuit must have been evacuated before performing this operation.
      Ask FixBot
      • Unplug the following connectors
      Ask FixBot
      • Alternator wire harnesses
      • Starter wire harnesses
      Ask FixBot
      • Use the necessary tools.
      Ask FixBot
      • Loosen the following screws
      Ask FixBot
      • Lift the vehicle
      • Remove the engine block
      Ask FixBot
Give the engine block a hug and perform absolutely every operation that can be done, even preventative maintenance, while it is easy to work on the engine block.
Author
with
DocTwingo
8,264 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 53
Past 30 Days: 199
All Time: 2,992
