PowerShot G7 X Mark II Front Cover Replacement
    1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: step 1, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: step 1, image 2 of 2
      • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
      Ask FixBot
    2. PowerShot G7 X Mark II Front Cover Replacement: step 2, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
      • Three 2.4 mm screws
      • Two 3 mm screws
      Ask FixBot
    3. PowerShot G7 X Mark II Front Cover Replacement: step 3, image 1 of 1
      • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
      Ask FixBot
    4. PowerShot G7 X Mark II Front Cover Replacement: step 4, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement: step 4, image 2 of 2
      • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
      Ask FixBot
    5. PowerShot G7 X Mark II Front Cover Replacement: step 5, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement: step 5, image 2 of 2
      • Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
      • Take time to determine how the actuator moves before trying to release it. If pressing it does not release it then it may need to be released by lightly pulling the LEFT side, rotating the actuator around it's right hand long side. (the hook end of a plastic halberd spudger may be used here to lightly tug the LEFT hand side)
      • If the FPC doesn't come out easily, you haven't yet released it. Do not force the FPC out. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
      Ask FixBot
    6. PowerShot G7 X Mark II Front Cover Replacement: step 6, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
      Ask FixBot
    7. PowerShot G7 X Mark II Front Cover Replacement: step 7, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement: step 7, image 2 of 2
      • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
      • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
      Ask FixBot
    8. PowerShot G7 X Mark II Front Cover Replacement: step 8, image 1 of 3 PowerShot G7 X Mark II Front Cover Replacement: step 8, image 2 of 3 PowerShot G7 X Mark II Front Cover Replacement: step 8, image 3 of 3
      • Open the battery compartment and remove the battery by flipping the small latch holding it in.
      • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
      Ask FixBot
    9. PowerShot G7 X Mark II Front Cover Replacement: step 9, image 1 of 2 PowerShot G7 X Mark II Front Cover Replacement: step 9, image 2 of 2
      • Release the ribbon cable that runs from the top cover assembly to the camera body by carefully manipulating the black actuator.
      • Pry the top cover button assembly off of the camera body by carefully detaching clips around the base of it.
      • If the top cover does not come off easily, ensure that the screw in the battery compartment was removed, and the FPC/ribbon cable has been released.
      Ask FixBot
    1. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: step 10, image 1 of 1
      • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
      Ask FixBot
    2. PowerShot G7 X Mark II Front Cover Replacement: step 11, image 1 of 1
      • Remove the USB/HDMI panel from the right side of the camera.
      Ask FixBot
    3. PowerShot G7 X Mark II Front Cover Replacement: step 12, image 1 of 1
      • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
      Ask FixBot
2 other people completed this guide.
Brandon
644 Reputation
4 Guides authored
USF Tampa, Team 12-3, Eyestone Spring 2017 Member of USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Members
48 Guides authored
2 Guide Comments
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Reply Share
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 65
All Time: 5,483
