Up to 20% off select tools
PowerRay Camera Module Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
124
All Time:
1,043
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. PowerRay Camera Module Replacement, Removing exterior parts: step 1, image 1 of 1
      • Remove the four protective parts on the back of the unit.
      • Check the position of the claws and be careful not to break any parts.
      Ask FixBot
    2. PowerRay Camera Module Replacement, Removing the rear panel: step 2, image 1 of 2 PowerRay Camera Module Replacement, Removing the rear panel: step 2, image 2 of 2
      • Remove all the following screws:
      • Red M2.5×6 (16 pieces)
      • 青 M2×5 (2本)
      Ask FixBot
    3. PowerRay Camera Module Replacement, Removing the bottom panel: step 3, image 1 of 2 PowerRay Camera Module Replacement, Removing the bottom panel: step 3, image 2 of 2
      • Remove the warning label and S/N label.
      • Remove the bottom exterior
      Ask FixBot
    4. PowerRay Camera Module Replacement, Removing the airtight module: step 4, image 1 of 2 PowerRay Camera Module Replacement, Removing the airtight module: step 4, image 2 of 2
      • Remove all screws that secure the airtight module to the housing
      • Red M2.5×12 (8 pieces)
      • Blue M2 x 5 (4 pieces)
      Ask FixBot
    5. PowerRay Camera Module Replacement, Disassembly of the airtight module: step 5, image 1 of 2 PowerRay Camera Module Replacement, Disassembly of the airtight module: step 5, image 2 of 2
      • Remove all screws from the airtight module
      • M2.5x8 (48 pieces)
      • Be careful not to cut the cables when removing the upper housing.
      Ask FixBot
    6. PowerRay Camera Module Replacement, Removing the Camera Module: step 6, image 1 of 1
      • Remove all the screws that attach the camera module
      • M2x5 (8 Pieces)
      Ask FixBot
    7. PowerRay Camera Module Replacement, Removing the Camera Module: step 7, image 1 of 2 PowerRay Camera Module Replacement, Removing the Camera Module: step 7, image 2 of 2
      • Remove the screws circled in red. M2×5 (2 pieces)
      • Remove the heatsink indicated by the orange arrow.
      Ask FixBot
    8. PowerRay Camera Module Replacement, Camera Module Removal: step 8, image 1 of 2 PowerRay Camera Module Replacement, Camera Module Removal: step 8, image 2 of 2
      • Unlock the flexible cable connector (raise the black lock)
      • Pull the flexible cable straight out.
      • The ferrite core indicated by the orange arrow will be reused, so keep it.
      Ask FixBot
    9. PowerRay Camera Module Replacement, Camera Module Removal: step 9, image 1 of 3 PowerRay Camera Module Replacement, Camera Module Removal: step 9, image 2 of 3 PowerRay Camera Module Replacement, Camera Module Removal: step 9, image 3 of 3
      • Cut the white magnet cable (red circle position)
      • Remove the LED connector (blue circle position)
      • After confirming that the flexible cable, magnet cable, and LED cable have been removed, pull out the camera module.
      Ask FixBot
    10. PowerRay Camera Module Replacement, First lot of camera modules: step 10, image 1 of 1
      • Modules that have been waterproofed with sealant at the position indicated by the arrow, are defective products from the initial lot and must be replaced.
      Ask FixBot
    11. PowerRay Camera Module Replacement, Installing the Camera Module: step 11, image 1 of 2 PowerRay Camera Module Replacement, Installing the Camera Module: step 11, image 2 of 2
      • Insert the camera cable into the main unit from the arrow position (flexible cable, magnet cable, LED cable)
      • Check that the O-ring is not scratched, cut, or damaged, apply grease to it and fit it firmly into the groove.
      Ask FixBot
    12. PowerRay Camera Module Replacement, Installing the Camera Module: step 12, image 1 of 2 PowerRay Camera Module Replacement, Installing the Camera Module: step 12, image 2 of 2
      • Attach the silicone cover at the arrow position.
      • Be careful when using tweezers not to damage the cable.
      Ask FixBot
    13. PowerRay Camera Module Replacement, Installing the Camera Module: step 13, image 1 of 1
      • Attach the camera module to the mount
      • Tighten diagonally a little at a time, tightening to a torque of 4.9 [cN・m].
      • Finally, tighten it one more time at 4.9 [cN・m]
      • Be careful not to pinch the O-ring or any debris when fixing.
      Ask FixBot
    14. PowerRay Camera Module Replacement, Installing the Camera Module: step 14, image 1 of 1
      • Connect the LED cable connector
      Ask FixBot
    15. PowerRay Camera Module Replacement, Installing the Camera Module: step 15, image 1 of 2 PowerRay Camera Module Replacement, Installing the Camera Module: step 15, image 2 of 2
      • Insert the ferrite core that you removed earlier.
      • Remove the Kapton tape from the end of the cable.
      • Install the flexible cable
      • Be careful not to touch the terminals after removing the Kapton tape.
      • When fastening the connector tabs, make sure the cables are inserted parallel to each other.
      Ask FixBot
    16. PowerRay Camera Module Replacement, Installing the Camera Module: step 16, image 1 of 2 PowerRay Camera Module Replacement, Installing the Camera Module: step 16, image 2 of 2
      • Replace the double-sided tape on the back of the heat sink
      • Remove the release paper from the double-sided tape and secure it with M2 x 5 (2 pieces).
      Ask FixBot
    17. PowerRay Camera Module Replacement, Installing the Camera Module: step 17, image 1 of 3 PowerRay Camera Module Replacement, Installing the Camera Module: step 17, image 2 of 3 PowerRay Camera Module Replacement, Installing the Camera Module: step 17, image 3 of 3
      • Peel off the coating of the magnetic cable on the main unit and insert the shrink tube.
      • Solder the cable on the main unit and the cable on the camera.
      • Fix the shrink tube with a heat gun
      Ask FixBot
    18. PowerRay Camera Module Replacement, Connection Test: step 18, image 1 of 1
      • The LED lights up just like in the picture.
      • Startup sound is normal
      • All motors and cameras are functioning normally.
      Ask FixBot
    19. PowerRay Camera Module Replacement, Upper module installation: step 19, image 1 of 2 PowerRay Camera Module Replacement, Upper module installation: step 19, image 2 of 2
      • Check that both O-rings are free of scratches, damage, and dirt, and apply grease to them and align them with the grooves.
      • Close the upper module, being careful not to catch any cables or debris.
      Ask FixBot
    20. PowerRay Camera Module Replacement, Upper module installation: step 20, image 1 of 1
      • Place the plate on and tighten all 48 screws
      • M2.5 x 8 (48 pieces)
      • Tightening torque = 39 [cN・m]
      • When tightening, always tighten diagonally
      Ask FixBot
    21. PowerRay Camera Module Replacement, Installing the upper exterior: step 21, image 1 of 2 PowerRay Camera Module Replacement, Installing the upper exterior: step 21, image 2 of 2
      • Install the M2.5 x 12 (8) screws.
      • Insert translation here
      Ask FixBot
    22. PowerRay Camera Module Replacement, Removing the airtight bolts: step 22, image 1 of 3 PowerRay Camera Module Replacement, Removing the airtight bolts: step 22, image 2 of 3 PowerRay Camera Module Replacement, Removing the airtight bolts: step 22, image 3 of 3
      • Remove the silicone sealant
      • Remove the airtight bolt with a 3mm hexagonal wrench
      Ask FixBot
    23. PowerRay Camera Module Replacement, Airtight test: step 23, image 1 of 3 PowerRay Camera Module Replacement, Airtight test: step 23, image 2 of 3 PowerRay Camera Module Replacement, Airtight test: step 23, image 3 of 3
      • Install the airtight test bolt in the place where the airtight bolt was removed.
      • Attach the hose and pump to the airtight test bolt
      • Pressurize to 140kPa, submerge in water, and check for no leaks for 3 minutes.
      Ask FixBot
    24. PowerRay Camera Module Replacement, Airtight bolt installation: step 24, image 1 of 3 PowerRay Camera Module Replacement, Airtight bolt installation: step 24, image 2 of 3 PowerRay Camera Module Replacement, Airtight bolt installation: step 24, image 3 of 3
      • Remove the airtight test bolt
      • Wrap the O-ring and sealing tape around the airtight bolt that you just removed and install it.
      Ask FixBot
    25. PowerRay Camera Module Replacement, Airtight bolt installation: step 25, image 1 of 2 PowerRay Camera Module Replacement, Airtight bolt installation: step 25, image 2 of 2
      • Seal the installed airtight bolts with sealant.
      Ask FixBot
    26. PowerRay Camera Module Replacement, Exterior installation: step 26, image 1 of 1
      • Attach M2.5 x 6 (14 pieces)
      • Attach M2×5 (2 pieces)
      Ask FixBot
    27. PowerRay Camera Module Replacement, Installation of exterior parts: step 27, image 1 of 3 PowerRay Camera Module Replacement, Installation of exterior parts: step 27, image 2 of 3 PowerRay Camera Module Replacement, Installation of exterior parts: step 27, image 3 of 3
      • Attach the four exterior parts
      • Attach the safety seal and S/N seal
      Ask FixBot
Finish Line
Special thanks to these translators:
jp en
100%
BTL Repair AU is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Kenta Uematsu
505 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 124
All Time: 1,043
