Up to 20% off select tools
PowerMac G4 M5183 RAM
Views: 7.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
77
All Time:
7,745
Comments: 1
1 comment on steps.
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the RAM Modules.
    1. PowerMac G4 M5183 RAM, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 PowerMac G4 M5183 RAM, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Ask FixBot
    1. PowerMac G4 M5183 RAM, RAM: step 2, image 1 of 2 PowerMac G4 M5183 RAM, RAM: step 2, image 2 of 2
      • Locate the RAM modules.
      • Pull side tabs outward. The RAM will pop out of the housing.
      Ask FixBot
Finish Line
13 other people completed this guide.
Author
with
Justin Petrilli
3,204 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 77
All Time: 7,745
