PowerMac G4 M5183 Graphics Card Removal
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
110
All Time:
10,696
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Removing the graphics card.
Tools
    1. PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Ask FixBot
    1. PowerMac G4 M5183 Graphics Card Removal, Graphics Card: step 2, image 1 of 2 PowerMac G4 M5183 Graphics Card Removal, Graphics Card: step 2, image 2 of 2
      • Remove the single screw with the Phillips #1 screwdriver.
      • Pull the graphics card up and out.
      Ask FixBot
Finish Line
13 other people completed this guide.
Justin Petrilli
3,204 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
156 Guides authored
2 Guide Comments
Do I need to avoid static to protect the board?
Jim Robson - Reply Share
Es ist eine deutsche Anleitung, aber auf der iFixit Übersicht als Englisch gekennzeichnet.
Toni Makkaroni - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 110
All Time: 10,696
