PowerLead Puto PLD003 Tripod Clip Replacement
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: step 1, image 1 of 1
    • Slide the battery eject button open to release the battery door.
    Ask FixBot
  2. PowerLead Puto PLD003 Tripod Clip Replacement: step 2, image 1 of 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
    Ask FixBot
  3. PowerLead Puto PLD003 Tripod Clip Replacement: step 3, image 1 of 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
    Ask FixBot
  4. PowerLead Puto PLD003 Tripod Clip Replacement: step 4, image 1 of 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
    Ask FixBot
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: step 5, image 1 of 2 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: step 5, image 2 of 2
    • Apply pressure upwards to remove the tripod clip.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 347
