Up to 20% off select tools
PowerLead Puto PLD003 Back Buttons Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
92
All Time:
751
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the screws that hold the camera together, how to remove the side panel from the camera, how to remove the back panel, and how to replace the back buttons.
    1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: step 1, image 1 of 1
      • Slide the battery eject button open to release the battery door.
      Ask FixBot
    2. PowerLead Puto PLD003 Back Buttons Replacement: step 2, image 1 of 1
      • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
      Ask FixBot
    3. PowerLead Puto PLD003 Back Buttons Replacement: step 3, image 1 of 1
      • Rotate the camera so that the underside is facing up.
      • Remove the four 5 mm Phillips #1 screws.
      Ask FixBot
    4. PowerLead Puto PLD003 Back Buttons Replacement: step 4, image 1 of 1
      • Place the camera on a flat surface, with its underside facing you.
      • Gently pull up on the side panel to remove it from the camera.
      Ask FixBot
    1. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: step 5, image 1 of 2 PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: step 5, image 2 of 2
      • Remove the three 4 mm Phillips #1 screws holding the weight.
      • Remove the weight.
      Ask FixBot
    2. PowerLead Puto PLD003 Back Buttons Replacement: step 6, image 1 of 1
      • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
      Ask FixBot
    3. PowerLead Puto PLD003 Back Buttons Replacement: step 7, image 1 of 1
      • Apply pressure to the back panel, away from the camera to remove.
      Ask FixBot
    4. PowerLead Puto PLD003 Back Buttons Replacement: step 8, image 1 of 2 PowerLead Puto PLD003 Back Buttons Replacement: step 8, image 2 of 2
      • Place the back panel so the buttons are facing down and the circuit board is facing up.
      • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
      Ask FixBot
    5. PowerLead Puto PLD003 Back Buttons Replacement: step 9, image 1 of 1
      • Set aside the circuit board.
      • These nubs are what is currently holding the buttons in place.
      • Carefully apply pressure and remove the set of buttons from the nubs.
      Ask FixBot
Author
with
Justin Tew
791 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 92
All Time: 751
