PowerBook G4 Titanium Onyx Lower Case Replacement
      • Turn the G4 over.
      • Remove the eight T8 Torx screws from the lower case.
      Ask FixBot
    1. PowerBook G4 Titanium Onyx Lower Case Replacement: step 2, image 1 of 1
      • Using your thumbs, slide the lower case away from you.
      • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      Ask FixBot
    2. PowerBook G4 Titanium Onyx Lower Case Replacement: step 3, image 1 of 1
      • Your laptop should look approximately like this.
      Ask FixBot
Attached Documents
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 4,650
