PowerBook G4 Titanium Onyx Logic Board Replacement
  1. PowerBook G4 Titanium Onyx Logic Board Replacement, Keyboard: step 1, image 1 of 1
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    Ask FixBot
  2. PowerBook G4 Titanium Onyx Logic Board Replacement: step 2, image 1 of 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    Ask FixBot
  3. PowerBook G4 Titanium Onyx Logic Board Replacement: step 3, image 1 of 1
    • Your laptop should look approximately like this.
    Ask FixBot
  4. PowerBook G4 Titanium Onyx Logic Board Replacement, RAM: step 4, image 1 of 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    Ask FixBot
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
    Ask FixBot
  5. PowerBook G4 Titanium Onyx Logic Board Replacement: step 6, image 1 of 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    Ask FixBot
  6. PowerBook G4 Titanium Onyx Logic Board Replacement: step 7, image 1 of 1
    Ask FixBot
  7. PowerBook G4 Titanium Onyx Logic Board Replacement, Airport Card: step 8, image 1 of 1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    Ask FixBot
  8. PowerBook G4 Titanium Onyx Logic Board Replacement, Hard Drive: step 9, image 1 of 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
    Ask FixBot
  9. PowerBook G4 Titanium Onyx Logic Board Replacement: step 10, image 1 of 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    Ask FixBot
  10. PowerBook G4 Titanium Onyx Logic Board Replacement: step 11, image 1 of 1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    Ask FixBot
  11. PowerBook G4 Titanium Onyx Logic Board Replacement: step 12, image 1 of 1
    Ask FixBot
  12. PowerBook G4 Titanium Onyx Logic Board Replacement, DVD Drive: step 13, image 1 of 1
    • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
    Ask FixBot
  13. PowerBook G4 Titanium Onyx Logic Board Replacement: step 14, image 1 of 1
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    Ask FixBot
  14. PowerBook G4 Titanium Onyx Logic Board Replacement: step 15, image 1 of 1
    • Turn the G4 over.
    • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
    Ask FixBot
  15. PowerBook G4 Titanium Onyx Logic Board Replacement: step 16, image 1 of 1
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Ask FixBot
  16. PowerBook G4 Titanium Onyx Logic Board Replacement, Modem: step 17, image 1 of 1
    • Turn the G4 over.
    • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
    Ask FixBot
  17. PowerBook G4 Titanium Onyx Logic Board Replacement: step 18, image 1 of 1
    • Lift the modem out by pulling up and to the right.
    • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
    Ask FixBot
  18. PowerBook G4 Titanium Onyx Logic Board Replacement: step 19, image 1 of 1
    • Disconnect the connector cable from the modem.
    Ask FixBot
  19. PowerBook G4 Titanium Onyx Logic Board Replacement, Logic Board: step 20, image 1 of 1
    • Remove the single T8 Torx screw located near the silver heat pipe.
    Ask FixBot
  20. PowerBook G4 Titanium Onyx Logic Board Replacement: step 21, image 1 of 1
    • Disconnect the three indicated connectors from the logic board.
    • Disconnect the orange PC card cage connector from the logic board.
    • The large multicolor cable may be difficult to free.
    Ask FixBot
  21. PowerBook G4 Titanium Onyx Logic Board Replacement: step 22, image 1 of 1
    • Turn the G4 over.
    • Remove the three T8 Torx screws from the logic board.
    • Be sure not to lose the rubber washers protecting the logic board from the lower two screws.
    Ask FixBot
  22. PowerBook G4 Titanium Onyx Logic Board Replacement: step 23, image 1 of 1
    • Disconnect the indicated connectors from the logic board, removing tape as necessary.
    Ask FixBot
  23. PowerBook G4 Titanium Onyx Logic Board Replacement: step 24, image 1 of 1
    • Carefully lift the logic board up and pull it away from you.
    • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
    • Remove the logic board from the computer.
    Ask FixBot
  24. PowerBook G4 Titanium Onyx Logic Board Replacement: step 25, image 1 of 1
    Ask FixBot
6 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
1 Guide Comment
just finished installing new logic board your instructions were great. but you missed a couple of plugs on the board. thanks for the help.
bill - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 11,344
