PowerBook G4 Titanium Onyx Airport Card Replacement
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
    Ask FixBot
  1. PowerBook G4 Titanium Onyx Airport Card Replacement: step 2, image 1 of 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    Ask FixBot
  2. PowerBook G4 Titanium Onyx Airport Card Replacement: step 3, image 1 of 1
    • Your laptop should look approximately like this.
    Ask FixBot
  3. PowerBook G4 Titanium Onyx Airport Card Replacement, Airport Card: step 4, image 1 of 1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    Ask FixBot
6 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 74
All Time: 10,075
