Up to 20% off select tools
PowerBook G4 Titanium DVI Latch Replacement
Views: 9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
102
All Time:
9,008
Comments: 5
5 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Latch mechanism located in the upper case.
    1. PowerBook G4 Titanium DVI Latch Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Titanium DVI Latch Replacement, Battery: step 1, image 2 of 2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      Ask FixBot
    1. PowerBook G4 Titanium DVI Latch Replacement, Lower Case: step 2, image 1 of 2 PowerBook G4 Titanium DVI Latch Replacement, Lower Case: step 2, image 2 of 2
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      Ask FixBot
    1. PowerBook G4 Titanium DVI Latch Replacement, Hard Drive: step 3, image 1 of 1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
      Ask FixBot
    2. PowerBook G4 Titanium DVI Latch Replacement: step 4, image 1 of 1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      Ask FixBot
    3. PowerBook G4 Titanium DVI Latch Replacement: step 5, image 1 of 1
      • Remove the hard drive by lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      Ask FixBot
    4. PowerBook G4 Titanium DVI Latch Replacement: step 6, image 1 of 1
      • Your laptop should look approximately like this.
      Ask FixBot
    1. PowerBook G4 Titanium DVI Latch Replacement, Latch: step 7, image 1 of 1
      • Use your thumbnails to push in and then lift the two fingers of the latch clip over the restraining bar.
      Ask FixBot
    2. PowerBook G4 Titanium DVI Latch Replacement: step 8, image 1 of 1
      • Now use your index fingers' nails to pull at the "elbows" of the clip, rotating it upward approximately 90 degrees, or until the latch pops out
      Ask FixBot
    3. PowerBook G4 Titanium DVI Latch Replacement: step 9, image 1 of 1
      • Insert the new latch by rotating the clip up and pushing the latch into place. Then rotate the clip back down, pushing in at the area where the clip bends around the latch. Make sure to insert the clip fingers back into their slots.
      Ask FixBot
5 other people completed this guide.
Attached Documents
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 102
All Time: 9,008
