Up to 20% off select tools
PowerBook G4 Titanium DVI DC-In Board Replacement
Views: 16K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
93
All Time:
16,451
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Tripped over your power cord? At least you don't have to replace the entire logic board.
    1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: step 1, image 2 of 2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      Ask FixBot
    1. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: step 2, image 1 of 2 PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: step 2, image 2 of 2
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      Ask FixBot
    1. PowerBook G4 Titanium DVI DC-In Board Replacement, DC-In Board: step 3, image 1 of 1
      • Disconnect the large DC-In connector from the right side of the logic board.
      Ask FixBot
    2. PowerBook G4 Titanium DVI DC-In Board Replacement: step 4, image 1 of 1
      • Remove the two T6 Torx screws from the DC-In board.
      Ask FixBot
    3. PowerBook G4 Titanium DVI DC-In Board Replacement: step 5, image 1 of 1
      • Lift the DC-In board out of the computer by pulling up and away from you.
      • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
      • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
      Ask FixBot
4 other people completed this guide.
Attached Documents
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 93
All Time: 16,451
